EIGRP Over The Top (OTP) Multi-Provider - IOS Supported?
David Undernehr
Question: Anyone know what platform and/or IOS version OTP is supported in?
I found some documentation that stated it was first supported in 15.3 but not other documentation to confirm this.
I've tested it on CSR1000V with XE 3.11
EIGRP-OTP#show ip route | incl LISP
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
D        5.5.5.5 [90/93994331] via 192.168.5.5, 01:39:29, LISP1
EIGRP-OTP#sh run | incl encap
  neighbor 192.168.5.5 GigabitEthernet3 remote 100 lisp-encap 1
EIGRP-OTP#show version | incl CSR
Cisco IOS Software, CSR1000V Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(1)S, RELEASE SOFTWARE (fc2)
cisco CSR1000V (VXE) processor with 2081417K/6147K bytes of memory.
EIGRP-OTP#
It works pretty well, but i would be more interessted when QoS (especially HQoS) will be supported on LISP interfaces
EIGRP-OTP(config-if)#service-policy output SHAPER
Traffic Shaping feature is not supported on interface LISP1
If you cannot enforce your QoS , it's almost useless.
David Undernehr
Found what I was looking for:
EIGRP OTP Availability
 ASR1K: IOS-XE 3.10 (June 2013)
 ISR G2: IOS 15.4(1)T (Nov 2013)
EIGRP-OTP#
Policer works
EIGRP-OTP#show policy-map interface  liSP 1
LISP1
  Service-policy output: POLICER
    Class-map: class-default (match-any)
      794 packets, 61422 bytes
      5 minute offered rate 3000 bps, drop rate 1000 bps
      Match: any
      police:
          cir 8000 bps, bc 17892 bytes
        conformed 663 packets, 51412 bytes; actions:
          transmit
        exceeded 131 packets, 10010 bytes; actions:
          drop
        conformed 3000 bps, exceeded 1000 bps
EIGRP-OTP#
Thanks Brandon for the replies. Good to know its working as designed.
