07-18-2011
07:35 AM
- last edited on
07-20-2023
11:01 PM
by
Translator
Since in
EIGRP a Query & a SIA Query
are 2 different packet types, would really want to know the differentiation between
EIGRP SIA Query & EIGRP Query
and when either of these is used by the Routers.
I went through the documentation & books only to confuse me more
Thanks.
Solved! Go to Solution.
07-18-2011 02:14 PM
When an EIGRP router has had a route to a prefix in its forwarding table and then loses that route, then the router will send a Query message to its neighbors. The router runs a timer waiting for the query response. When the neighbor receives the query it determines whether it can respond immediately or if it must forward the query to its neighbors. A router that has forwarded a query to its neighbors can not respond to the original query until it has received a response from all of its neighbors. If the timer expires at the originating router, perhaps because the neighbor is still wait for a response to a query that it forwarded, then the originating router will tear down the neighbor relation because it is Stuck In Active (thus the phrase SIA).
In earlier designs of EIGRP there was no way for a router to indicate that it was still waiting for response to a forwarded query and sometimes the neighbor relationship would be terminated even though both neighbors were really still communicating effectively. So Cisco added a feature in EIGRP such that after sending the original query when it lost a route then the originating router will still wait for responses and will still run the timer. But with the new feature the originating router can send a SIA Query to its neighbors before the timer expires. A neighbor may be waiting for a response to a forwarded query and can not respond to the original query but it is able to respond to the SIA query. Now the originating router knows that it must still wait for a response before it can resolve whether there is a new path to the destination, but it no longer needs to tear down the neighbor relation with the neighbor router.
Rick
07-19-2011 05:08 AM
Shehjad
Yes there is a time for the SIA Query and it is one half of the active query timer.
Yes I believe that nested SIA Query is supported.
There was an interesting presentation on EIGRP which included some discussion of the SIA Query at the recent Cisco Live. If you have access to Cisco Live presentations (perhaps through Cisco Live Virtual) you might want to look at the session Care and Feeding of EIGRP Networks.
Rick
07-20-2011 06:32 AM
It's not really nested or recursive. Each router independently runs thru the diffusing update algorithm to reconcile the active route. If a router receives a Query from his successor he looks for a feasible alternative in his topo table. If he has one, he responds with it. If not, he sends a Query to all of his peers (except the interface he received the Query on.) At the time of going active, the timer starts and if 1.5 minutes goes by without a Reply, an SIA-Query is sent to the peer(s) who didn't respond. If they're still waiting on a Reply themselve, they respond with an SIA-Reply. When their timer pops (1.5 minutes) that router will also send an SIA-Query, etc.
It appears to me that you have the process down quite well, but I'm not sure where the nested or recursive description comes from.
Don
07-18-2011 12:29 PM
Hi, basically a eigrp SIA is a state when a router running eigrp has lost a connection to a neighbour and hasnt received a response to a query for that lost route in the allocated time = 180 secs. when this time expires the router removes the eigrp neighbour and logs a SIA event.
res
Paul
07-18-2011 02:14 PM
Rick
07-18-2011
09:20 PM
- last edited on
07-20-2023
10:55 PM
by
Translator
Thank you pdriver for replying.
Thanks a lot Rick. This really helped.
R1====>Query/SIA Query====>R2====>Query/SIA Query====>R3====>Query/SIA Query====>R4
Could you also please explain if there's any specific time for the SIA query(e.g. 50% of Active-Timer) and whether there are nested SIA queries too as depicted above.
Thank you.
Shehjad
07-19-2011
12:17 AM
- last edited on
07-20-2023
10:57 PM
by
Translator
Hi Shehjad,
The SIA state means that an EIGRP router has not received a reply to a query from one or more neighbors within the time allotted (approximately 3 minutes). When this happens, EIGRP clears the neighbors that did not send a reply and logs a
DUAL-3-SIA
error message for the route that went active.
Please click on the correct answer if this answered your question.
Naidu.
07-19-2011 05:08 AM
Shehjad
Rick
07-19-2011 05:15 AM
Just to add to Rick's excellent posts. The main tool to use to limit SIAs in an EIGRP network is summarisation. If you have a multi-site network and you do not summarise then an EIGRP query can extend across the entire network and you are far more likely to experience SIAs.
If you summarise each site then you limit the scope of the queries which can make a significant difference in the amount of SIAs experienced.
I have seen SIAs in an EIGRP network usually because one router is heavily overloaded and does not have the resources to respond in time.
Jon
07-19-2011 08:02 AM
Thanks a ton Rick. You rock, 5 points to Griffindor
I saw the presentation "Care and Feeding of EIGRP Networks" & found it to be really helpful.
Last but not the least, want to thank pdriver Latchum & Jon too for their ever helpful comments.
07-19-2011 04:38 PM
I'm glad you found "The Care and Feeding of EIGRP Networks" helpful. :^)
Don. (presenter of that session)
07-19-2011
09:33 PM
- last edited on
07-20-2023
10:58 PM
by
Translator
Thank you very much Don for such insightful presentation.
Although would like to know if such nested SIA queries are suppoorted. You also mentioned in your slides that SIA queries should be as close to the Origin as possible so would you also like to shed some light on this too?
Shaz
07-20-2011 04:40 AM
Define "nested SIA Queries". What really happens is that a Query is sent and after 1/2 the active time (1.5 min) if a Reply isn't received, and SIA-Query is sent to detemine if the peer is also still waiting on a Reply. If he is also still waiting, he replies with an SIA-Reply. I'm not sure what you mean by nested.
As for the second question, I said that the above process will normally make an SIA happen (if one happens) closer to the actual source of the problem (dirty link, router out of resources, etc.) because the other rotuers are using the SIA-Query/SIA-Replay process to verify the state of health between the routers that still have their timers running. If the problem is realy between R3 and R4 above (dirty link, for example), the SIA-Query/SIA-Reply exchange would fail between them, causing that peer relationship to be reset, sending a Reply back to R2 and then R1.
07-20-2011 05:35 AM
By Nested SIA Query I mean that R1 will go Active on a route & will send a Query & in 1.5 SIA Query to R2. If R2 doesn't know the route it will Query to R3, if R3 doesn't knows the route it'll Query to R4. In 1.5 will R2 also send SIA Query to R3 & eventually will R3 also send SIA Query to R4?
What I understood is SIA Queries will be generated RECURSIVELY till the LEAF ROUTER if that route is not known.
Thank you for replying.
-Shaz
07-20-2011 06:32 AM
Don
07-20-2011 09:10 PM
Thanks a lot Don.
Now I can smell what EIGRP cooks
Appreciate everyone who contributed to answer the queries.
Shaz
03-20-2016 08:35 AM
When an EIGRP router loses a route to a destination and there is no feasible successor exists, the route is marked as "Active". Then, it will send EIGRP Query messages to its neighbors. The EIGRP router will set an Active timer after sending a Query to a neighbor and wait for a reply. If the neighbor does not respond within the Active timer, the router will send another Query (SIA Query) to ask the status of the original Query. If the neighbor cannot response the second SIA Query, the router will reset the neighbor relationship.
