10-11-2013 07:31 AM - edited 03-04-2019 09:17 PM
Eigrp running on all three routers R1 has some loopback address and it sending summary routes to both spoke r2 and r3, this two spoke router receving summary routes but i want to receive specific routes on r2 this router already receving summary route from r1, is there any way to get specific(loop address) routes from r1 to r2 while it send summary route. Thanks in advance.
Solved! Go to Solution.
10-11-2013 07:36 AM
on the Hub:
ip prefix-list LEAK permit 10.1.1.0/24
ip prefix-list LEAK permit 10.1.2.0/24
ip prefix-list LEAK permit 10.1.3.0/24
route-map LEAKMAP
match ip address prefix LEAK
interface s1/0
ip summary-address eigrp 1 10.0.0.0 255.0.0.0 leak-map LEAKMAP
This will send the summary and the subnet routes to both spokes, you can filter on R3 inbound for the specific subnets using a distribute-list with a prefix-list.
Alain
10-12-2013 03:07 AM
Hi syed,
Leak-map is a technique which is used with summarization. It is used in the situations where you want to summarize routes but still want some routes to be preffered over others for some reasons. Leak map reffernces an access-list and whatever network is permitted in the access-list will be leaked along summary route.
Refer:http://deepakarora1984.blogspot.in/2012/03/eigrp-leak-maps.html
http://blog.ine.com/2007/12/26/how-do-prefix-lists-work/
Sathvik K V
10-11-2013 07:36 AM
on the Hub:
route-map LEAKMAP
interface s1/0
Alain
10-11-2013 08:06 AM
Hi syed,
The above solution should work
Sathvik K V
10-11-2013 04:14 PM
Hi, i try as u said but it didn't work, i change some new address on loopback. here is my config
Router1
R1#sh running-config
Building configuration...
Current configuration : 2494 bytes
upgrade fpd auto
version 12.4
hostname R1
ip tcp synwait-time 5
interface Loopback1
interface Loopback2
ip address 192.168.2.1 255.255.255.0
interface Loopback3
ip address 192.168.3.1 255.255.255.0
interface Loopback4
ip address 192.168.4.1 255.255.255.0
interface Loopback5
ip address 192.168.5.1 255.255.255.0
interface FastEthernet0/0
no ip address
shutdown
duplex half
interface Serial1/0
ip address 172.12.23.1 255.255.255.0
encapsulation frame-relay
no ip split-horizon eigrp 1
ip summary-address eigrp 1 192.168.0.0 255.255.248.0 5 leak-map LEAK
serial restart-delay 0
frame-relay map ip 172.12.23.2 102 broadcast
frame-relay map ip 172.12.23.3 103 broadcast
interface Serial1/1
no ip address
shutdown
router eigrp 1
network 172.12.23.0 0.0.0.255
network 192.168.1.1 0.0.0.0
network 192.168.2.1 0.0.0.0
network 192.168.3.1 0.0.0.0
network 192.168.4.1 0.0.0.0
network 192.168.5.1 0.0.0.0
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip prefix-list LEAK seq 5 permit 192.168.1.0/24
ip prefix-list LEAK seq 10 permit 192.168.2.0/24
ip prefix-list LEAK seq 15 permit 192.168.3.0/24
ip prefix-list LEAK seq 20 permit 192.168.4.0/24
ip prefix-list LEAK seq 25 permit 192.168.5.0/24
route-map LEAKMAP permit 10
match ip address prefix-list LEAK
control-plane
R1#sh ip route
Gateway of last resort is not set
172.12.0.0/24 is subnetted, 1 subnets
C 172.12.23.0 is directly connected, Serial1/0
C 192.168.4.0/24 is directly connected, Loopback4
C 192.168.5.0/24 is directly connected, Loopback5
C 192.168.1.0/24 is directly connected, Loopback1
C 192.168.2.0/24 is directly connected, Loopback2
C 192.168.3.0/24 is directly connected, Loopback3
D 192.168.0.0/21 is a summary, 00:24:55, Null0
R1#sh ip eigrp ne
R1#sh ip eigrp neighbors
IP-EIGRP neighbors for process 1
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
1 172.12.23.3 Se1/0 142 00:31:37 214 1284 0 15
0 172.12.23.2 Se1/0 148 00:32:52 62 372 0 14
Router 2
R2#sh running-config
Current configuration : 1729 bytes
upgrade fpd auto
version 12.4
hostname R2
boot-start-marker
boot-end-marker
logging message-counter syslog
archive
log config
hidekeys
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
ip address 172.12.23.2 255.255.255.0
frame-relay map ip 172.12.23.1 201 broadcast
frame-relay map ip 172.12.23.3 201 broadcast
router eigrp 1
no auto-summary
no ip http server
R2#sh ip eigrp neighbors
(sec) (ms) Cnt Num
0 172.12.23.1 Se1/0 178 00:34:50 55 330 0 18
R2#sh ip route eigrp | i 192
D 192.168.0.0/21 [90/2297856] via 172.12.23.1, 00:27:25, Serial1/0
R2#sh ip eigrp topology
IP-EIGRP Topology Table for AS(1)/ID(172.12.23.2)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 192.168.0.0/21, 1 successors, FD is 2297856
via 172.12.23.1 (2297856/128256), Serial1/0
P 172.12.23.0/24, 1 successors, FD is 2169856
via Connected, Serial1/0
Router 3
R3#sh running-config
upgrade fpd auto
version 12.4
hostname R3
boot-start-marker
boot-end-marker
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0
ip address 172.12.23.3 255.255.255.0
frame-relay map ip 172.12.23.1 301 broadcast
frame-relay map ip 172.12.23.2 301 broadcast
router eigrp 1
no auto-summary
no ip http server
R3#sh ip route eigrp | i 192
D 192.168.0.0/21 [90/2297856] via 172.12.23.1, 00:30:38, Serial1/0
R3#
R3#sh ip eigrp ne
R3#sh ip eigrp neighbors
(sec) (ms) Cnt Num
0 172.12.23.1 Se1/0 178 00:37:18 69 414 0 18
R3#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
D 192.168.0.0/21 [90/2297856] via 172.12.23.1, 00:30:56, Serial1/0
10-11-2013 11:00 PM
After i review my config i found mention wrong leakmap cmd on summary route that is why it not work, now its working fine.
10-11-2013 11:02 PM
route-map LEAKMAP
interface s1/0
can you please explaing me what is the use of ip prefix-list and what is leak map.
10-12-2013 03:07 AM
Hi syed,
Sathvik K V
10-12-2013 03:57 AM
Hi sathvik,
thanks for you reply, just now i try using access-list instead of ip prefix-list like
ip summary-address eigrp 100 192.168.1.0 255.255.248.0 leak-map LEAK
ip access-list 10 permit 192.168.1.0 0.0.0.255
ip access-list 10 permit 192.168.2.0 0.0.0.255
ip access-list 10 permit 192.168.3.0 0.0.0.255
ip access-list 10 permit 192.168.4.0 0.0.0.255
route-map LEAK permit 1
match ip-address 10
It also doing the same job.
10-12-2013 04:55 AM
Hi Syed,
Access-list can also be used depends on scenario and the way you implement. Its just what you want to match in the route map.
Sathvik K V
10-12-2013 05:22 AM
Dear friends,
Just to add a small remark - whenever filtering a set of routes in routing protocols, I recommend using prefix lists instead of ACLs. Prefix lists are easier to read and to understand, they are optimized for prefix and netmask matching, and they allow matching both for subnet addresses and netmasks. Standard ACLs perform matching based only on the subnet address but they are not capable of matching the subnet's mask, i.e. they are not able to differentiate between, say, 10.0.0.0/8 and 10.0.0.0/16. Extended ACLs support matching of netmasks in certain circumstances but they are so counter-intuitive that I do not want to even start discussing them.
The bottom line is - if you can use prefix lists then use them.
Best regards,
Peter
10-11-2013 01:02 PM
Hello
Just to add to Cadet Allan post
You haven't stated if these links are Ethernet of Serial. ( I assume Fastethernet or Gig ports)
Anyway to avoid a discard route being entered in you rib table apply an admin distance of 255 at the end of the summary leak map command
Also if you are using serial you will need to configure a virtual interfaces on either serail interface as leap map isn't available other wise
Res
Paul
