03-20-2018 06:45 PM - edited 03-07-2019 12:22 AM
Hi All,
The traffic flow are from A to B , B to A , A to C and C to A, Please refer attached file for more detail.
Questions
Please advise.
03-21-2018 05:39 AM
One the requirements to enable the communication between EIGRP routers is they must use the same AS, now if yu have router with different AS, they will be able to communicate between the routers with the common AS, for example AS 10 will not able to communicate with AS 11, you could require a NAT to communicate the same networks.
Now my suggestion is try to change the IP addressing if it is possible because it could generate any confusion.
Hope it is useful
03-21-2018 07:05 AM
Hi Moisa,
Do you mean that we change the IP in C1 and D1 network? use different subnet network?
Please advise.
Thanks.
03-22-2018 03:52 AM - edited 03-22-2018 03:52 AM
Apologies I verified the IP addressing again, now my question is, why you need 2 EIGRP processes? are you making mutual redistribution?
03-21-2018 09:30 AM
how do you trigger the backup links ?
Either way, you need to mutually redistribute the EIGRP ASs, otherwise one doesn't know about the routes to the other.
Also, create a DHCP pool with both HSRP addresses as default routers.
03-21-2018 05:52 PM
Hi Pauwen,
Its use IPSLA to trigger the back up link.
