Eigrp showing different FD value
sanishcj123
Hi All
I have come accross one issue regarding the EIGRP.  In the output its showing a differenet value as FD as compare to the composit metric. and its is showing for a particular route only. Please find the out below. I have highligted the difference.
P  172.31.254.216/32, 2 successors, FD is 378112, serno 9839848
        via  172.31.254.50 (378624/128256), GigabitEthernet0/3
        via 172.27.100.77  (378624/378368), GigabitEthernet0/1
Not understanding why the FD is showing 378112 instead 378624
Thank and regards
Sanish
Peter Paluch
Hello Sanish,
This is because the FD is not really the current lowest distance to the destination - rather, it is a record of the lowest distance to the destination since the last time the route went from Active to Passive state. In other words, the FD is a historical minimum of the distance to the destination, with the history starting again when the route transitions from Active to Passive state. If the current distance increases in such a way that no diffusing computation is required (i.e. after the distance increase, the router providing the least actual distance still passed the feasibility condition check), the FD will remain at its present value while the current distance increases. Exactly this has happened in your case.
The FD, contrary to popular belief, is not the current distance to the destination, and it is not advertised in EIGRP. The FD is assigned to each known route but is used only locally by each router in the Feasibility Condition.
Best regards,
Peter
Hi Peter
Thanks a lot for the reply with detailed explanation.
Best regards
Sanish Joseph
You are heartily welcome. Please feel welcome to join us here at CSC at any time again!
Best regards,
Peter
