EIGRP:Single Peering over Parallel Links
martin_lx1980
There are many links between two eigrp routers. A feature called single peering over parallel links could implement that only one neighbor relationship exists no matter how many links between the routers
But I don't know which command I need to implement this feature. I think it is not the default behavior for eigrp
Thanks a lot
Martin
Peter Paluch
Martin,
You're probably reading the "Advances in EIGRP" document. Sadly, I haven't seen this feature implemented anywhere. Please correct me anyone if I am wrong on the subject but this feature, as it seems, never came into production.
Best regards,
Peter
P.S.: Martin, did I answer all your questions about the CR-mode? I admit I haven't kept an eye on the discussion for quite a time. If there are any unanswered issues please let me know.
Peter Paluch
Martin,
Best regards,
Peter
Peter, I enjoyed the read about CR-mode, that was VERY interesting and learned a lot. Sorry to kinda hijack the thread here.
Peter, enjoy to see your reply again. Indeed I am reading "Advance in EIGRP"  document and see this feature introduced. But I could not  find any other document to specify this feature and also could not find any IOS command about this.
  I have full knowledge about CR-mode and thank you very much for your help. I expect to have more discuss with you if I have another confused problems.
Best Regards
Martin
Best Regards
Martin
