Eigrp stub Problem
rawatmohinder
Router TK2 is configured for EIGRP as shown below:
router eigrp 100
network 10.0.0.0
eigrp stub
Based on this configuration, which types of routes will be advertised with the EIGRP
configuration as shown? (Choose two)
A. Static
B. Receive only
C. Summary
D. Stub
E. Connected
F. dynamic
Kindly explain your answers a little bit.. that why u choose that answers.
Mahi
pkhatri
Level 11
Level 11
Mahi,
The answer will be C and E.
The reason is that when you enter in the 'eigrp stub' command, it will actually appear in the running config as 'eigrp stub connected summary', which means that connected and summary routes will be announced by default.
Pls do take the effort to rate the post if it helps.
Paresh
