EIGRP through tunnels
Bob Greer
Level 4
Level 4
Hi There,
Thanks for reading.
I have WAN routers which ping each other, have tunnels up / up (those IPs ping) and can ssh from one to the other.  My problem is tunnels are not allowing an EIGRP neighborship to form.  No auto-summary is included in EIGRP config.  The tunnel infs are set to no-passive in EIGRP.  And there's no EIGRP traffic.  I have route-map commands settag and denytag lines marking routes as 99 IN and denying 99 routes OUT (on the remote side).
Debug route-map events on remote side is blank: nothing logged.
Hello
WHRT shows your tunnels are shutdown and also you dont have any network statement in the eigrp process for those tunnels
interface Tunnel10012882
description VPNtoHV1
ip address 10.3.131.30 255.255.255.252
shutdown
interface Tunnel14012884
description VPNtoUS3
ip address 10.150.252.138 255.255.255.252
shutdown
router eigrp 100
network 10.145.16.0 0.0.15.255
Kind Regards
Paul
Bob Greer
Level 4
Level 4
this attachment is the local hub router
I just found debug eigrp ? (instead of debug ip eigrp ?).  Got more output.  This keeps repeating.  NSF Send timer looks interesting.
rtmx9WH1#
*Feb 16 01:55:45.733: EIGRP-Timer: Hello (Vl111) Getting Context
*Feb 16 01:55:45.733: EIGRP-Timer: NSF RS Send Timer IS NOT running
*Feb 16 01:55:45.734: EIGRP: Sending HELLO on Vl111 - paklen 20
*Feb 16 01:55:45.734:   AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Feb 16 01:55:45.734: EIGRP-Timer: NSF RS Send Timer IS NOT running
*Feb 16 01:55:45.734: EIGRP-Timer: Hello (Vl111) Start Jittered in (5000:15)
rtmx9WH1#
*Feb 16 01:55:50.229: EIGRP-Timer: Hello (Vl111) Getting Context
*Feb 16 01:55:50.229: EIGRP-Timer: NSF RS Send Timer IS NOT running
*Feb 16 01:55:50.229: EIGRP: Sending HELLO on Vl111 - paklen 20
*Feb 16 01:55:50.229:   AS 100, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
*Feb 16 01:55:50.229: EIGRP-Timer: Hello (Vl111) Start Jittered in (5000:15)
Hello
shutdown
shutdown
router eigrp 100
Kind Regards
Paul
