EIGRP to BGP Redistribution
pgyogeshkumar
I have certain routes learnt in EIGRP and i need to redistribute into BGP.
Please note that I have to  filter just specific routes from EIGRP to learn in BGP so I use route-map while re-destributing EIGRP to BGP to filter the prefixes.
I have below queries now
1. Please confirm if I can set as path prepend while redistributing EIGRP to BGP in the same route map applied for Redistribute EIGRP to BGP for the required prefixes ?
2. IF the question to above is Yes, pls confirm the routes learnt in BGP now will advertise automatically to its BGP peer with same AS-Path prepended?
You cannot set up AS-path prepend when you are redistributing from an IGP (in this case EIGRP) to BGP.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
