EIGRP to BGPAS 1 and AS2 distribution or routing issue.
CiscoPurpleBelt
Level 6
Level 6
See attachment - looking for some help.
All routers in EIGRP can only ping up to the interfaces marked with a red line, and all BGP routers can ping every router except past the BGP interface on R5.
R5 is where BGP65000 (which has 4 routers as you can see in BGP65000) is redistributed into EIGRP100, and R5 can ping everything in the topology.
R7 joins EIGRP100 and 200. As I stated there are no comms issues with EIGRP routers except going past the interaces marked with a red wall/line.
R11 is a Route-Reflector. See applicable configs for R11, R5, and R6 since the issue seems to pertain to either my RR configs on R11, or distribution configs on R5. No static routes/GWs, ACLs, route-maps, filters, etc. are configured.
R11#sh running-config | section router
router bgp 65000
bgp router-id 11.11.11.11
bgp log-neighbor-changes
network 11.11.11.11 mask 255.255.255.255
network 50.1.1.4 mask 255.255.255.252
network 100.1.1.1 mask 255.255.255.255
network 203.3.3.0 mask 255.255.255.252
network 203.4.4.0
neighbor 50.1.1.6 remote-as 65000
neighbor 50.1.1.6 route-reflector-client
neighbor 203.3.3.1 remote-as 65000
neighbor 203.3.3.1 route-reflector-client
neighbor 203.4.4.2 remote-as 65000
neighbor 203.4.4.2 route-reflector-client
R5#sh running-config | section router
router eigrp 100
network 5.5.5.5 0.0.0.0
network 203.2.2.0 0.0.0.3
redistribute bgp 65000 metric 10000 100 255 1 1500
router bgp 65000
bgp router-id 5.5.5.5
network 5.5.5.5 mask 255.255.255.255
network 203.1.1.0 mask 255.255.255.252
redistribute eigrp 100
neighbor 203.1.1.2 remote-as 65001
neighbor 203.3.3.2 remote-as 65000
R6#sh running-config | section router
router eigrp 100
network 6.6.6.6 0.0.0.0
network 203.2.2.0
network 203.3.3.0
See anything that stands out or may be incorrect?
CiscoPurpleBelt
Level 6
Level 6
Added the "bgp redistribute-internal" config under bgp 65000 on R5 and vioala!
Looks like BGP would not share iBGP routes with EIGRP (IGP) without this command.
CiscoPurpleBelt
Level 6
Level 6
Anyone?
CiscoPurpleBelt
Level 6
Level 6
