EIGRP Traffic Sharing
aamer.ali
Dear All,
I have two links from ISP 6Mb and 2Mb so i want to confiugre load sharing so that 75% of inbound traffic to interet will go from 6Mb link and other 25% traffic will go from 2Mb link..
Aamer
6 Accepted Solutions
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Inbound, from the ISP?  Have you spoken with your ISP?
cadet alain
if this is outbound traffic destined to Internet then you must unequal cost load-sharing.
for this you must make the successor/feasible successor  feasible distance ratio=3/1 and use variance so that FD of Feasible successor * variance <= FD of successor.
Alain
Hi Alain,
Two slight corrections:
  1. There is no such thing as FD of Feasible Successor or FD of Successor. There is only a FD of the route itself, which is the lowest known distance since the last time the route went passive.
  2. For a worse route through a Feasible Successor to be accepted thanks to variance, the following equation must hold: total metric via Feasible Successor <= total metric via Successor * variance
Best regards,
Peter
My interpretation of what Aamer was indicating focuses on the phrase "traffic to interet" and in that sense it would be from the inside network, inbound to the router, and then forwarded toward the ISP.
As suggested by Alain using EIGRP variance may be a possibility. I have a couple of questions about this:
- is it a single ISP with 2 links or is it 2 ISP and each one has a single link:
- Has the ISP agreed to run EIGRP with you on both links?
I have an alternative that you might consider. Set up the 6 Mb link as primary and the 2 Mb link as backup in case of problems with the primary. And then configure Policy Based Routing to identify some types of traffic and to send these over the 2 Mb link.
Rick
Rick
Hello
The easiest way I think of eigrp unequal load balancing is dividing the highest/lowest composite metric of say the two paths you wish to use
(Eigrp has already calculated this metric using the lowest bw +total delay values for them)
Sh ip eigrp topology - will give you these metrics
This value is then applied via the variance command to the eigrp process, And then if applicable apply per-packet load sharing to the necessary interfaces
To test you changes
Sh ip route
Sh ip cef exact-route scr dst (this should show packets being load shared over both links pertaining to the variance value applied)
Res
Paul
Kind Regards
Paul
Disclaimer
Posting
Rick, re-reading the OP, I think you're correct ". . .  inbound traffic to interet . . ." may mean egress from user's router to the Internet.
Aamer, if this is want you meant, if the device supported PfR (especially the PIRO variant if you want it to inject into EIGRP), that would be the optimal way to load balance the egress traffic.
Also, Aamer, realize EIGRP load balancing will direct flows in proportion to unequal costs, it doesn't balance actual loading (as does PfR).  For example, 3 light usage flows could be using the 6 Mbps interface while a single heavy usage flow is saturating the 2 Mbps link.
9 Replies 9
Joseph W. Doherty
Disclaimer
Posting
cadet alain
Alain
Hi Alain,
Best regards,
Peter
Hi Peter,
yes you are correct, thanks for correcting me.
Alain
Rick
Rick
Disclaimer
Posting
Hello
To test you changes
Sh ip route
Res
Paul
Kind Regards
Paul
aamer.ali
Dear All,
Thanks for your guidance, i will do the below and get back to you.
I will configure EIGRP with unequal load balancing and Variance. I will manually configure bandwidth on both outbound interface.
I have Cisco 2801 with 1 extra HWic Card.
Aamer
Aamer did you manage to make this work ;) ?
