EIGRP tunnels question.
ry0534cisco
I am a bit confused about this router config from a branch location of an enterprise network. They use EIGRP tunnels as backups to the HQ.
I have pasted what I believe is relevant to my question. Under the sh ip pro it states:
Address Summarization:
    10.102.73.0/24 for Tunnel1, Tunnel2, Tunnel3
but that network is for the inside user LAN. What does this command mean?
And the route table has this EIGRP config:
D       10.102.73.0/24 is a summary, 00:17:44, Null0
Rt1#sh int des
Interface                      Status         Protocol Description
Fa0/0                          up             up       ****TRUNK TO SWITCH****
Fa0/0.1                        up             up       **** POS ****
Fa0/0.2                        up             up       **** Users ****
Fa0/1                          up             up       Verizon DSL circuit
BR0/1/0                        up             up       Verizon ISDN circuit SPID1
BR0/1/0:1                      down           down
BR0/1/0:2                      down           down
Lo0                            up             up
Lo2                            up             up
Tu1                            up             up       GRE VPN2 Primary Tunnel
Tu2                            up             up       GRE VPN2 Secondary Tunnel
Tu3                            up             up       GRE VPN3 Backup Tunnel to HQ
Rt1#sh ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  up                    up
FastEthernet0/0.1          10.102.73.1     YES NVRAM  up                    up
FastEthernet0/0.2          10.102.73.129   YES NVRAM  up                    up
FastEthernet0/1            72.86.158.250   YES NVRAM  up                    up
BRI0/1/0                   192.168.1.59    YES NVRAM  up                    up
BRI0/1/0:1                 unassigned      YES unset  down                  down
BRI0/1/0:2                 unassigned      YES unset  down                  down
Loopback0                  10.202.73.1     YES NVRAM  up                    up
Loopback2                  10.90.1.78      YES NVRAM  up                    up
Tunnel1                    10.99.5.54      YES NVRAM  up                    up
Tunnel2                    10.99.133.54    YES NVRAM  up                    up
Tunnel3                    10.99.69.54     YES NVRAM  up                    up
Rt1#sh ip eig ne
IP-EIGRP neighbors for process 100
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
3   10.99.133.53            Tu2               14 01:18:31  459  2754  0  557854279
2   10.99.5.53              Tu1               13 01:18:38   71   426  0  552639512
1   10.99.69.53             Tu3               14 01:18:41  157   942  0  1267476614
   66.0.0.0/32 is subnetted, 1 subnets
S       66.187.216.11 [1/0] via 72.86.158.1
     216.143.116.0/32 is subnetted, 2 subnets
S       216.143.116.13 [1/0] via 72.86.158.1
S       216.143.116.12 [1/0] via 72.86.158.1
     172.31.0.0/32 is subnetted, 2 subnets
S       172.31.0.6 [1/0] via 72.86.158.1
S       172.31.0.10 [1/0] via 72.86.158.1
     10.0.0.0/8 is variably subnetted, 9 subnets, 4 masks
C       10.99.69.52/30 is directly connected, Tunnel3
C       10.90.1.78/32 is directly connected, Loopback2
C       10.102.73.0/25 is directly connected, FastEthernet0/0.1
C       10.99.5.52/30 is directly connected, Tunnel1
C       10.202.73.1/32 is directly connected, Loopback0
C       10.102.73.128/25 is directly connected, FastEthernet0/0.2
C       10.99.133.52/30 is directly connected, Tunnel2
S       10.5.251.12/32 [1/0] via 72.86.158.1
     72.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       72.86.158.0/24 is directly connected, FastEthernet0/1
S       72.37.251.30/32 [1/0] via 72.86.158.1
D*EX 0.0.0.0/0 [170/19467008] via 10.99.5.53, 01:18:50, Tunnel1
C    192.168.0.0/22 is directly connected, BRI0/1/0
Rt1#sh ip pro
Routing Protocol is "eigrp 100"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  Default networks flagged in outgoing updates
  Default networks accepted from incoming updates
  EIGRP metric weight K1=1, K2=0, K3=1, K4=0, K5=0
  EIGRP maximum hopcount 100
  EIGRP maximum metric variance 1
  EIGRP stub, connected, summary
  Redistributing: eigrp 100
  EIGRP NSF-aware route hold timer is 240s
  Automatic network summarization is not in effect
      BRI0/1/0
      Summarizing with metric 28160
  Maximum path: 4
  Routing for Networks:
    10.99.5.52/30
    10.99.69.52/30
    10.99.133.52/30
    10.102.73.0/25
    10.102.73.128/25
    10.202.73.1/32
    192.168.0.0/22
  Passive Interface(s):
    FastEthernet0/0
    FastEthernet0/0.1
    FastEthernet0/0.2
    FastEthernet0/1
    BRI0/1/0:1
    BRI0/1/0:2
    Loopback0
    Loopback2
Routing Information Sources:
    Gateway         Distance      Last Update
    (this router)         90      00:17:57
    10.99.69.53           90      00:17:57
    10.99.5.53            90      00:00:05
    192.168.1.1           90      01:15:06
    10.99.133.53          90      00:00:05
  Distance: internal 90 external 170
interface Tunnel1
description GRE VPN2 Primary Tunnel
bandwidth 384
ip address 10.99.5.54 255.255.255.252
ip mtu 1400
ip tcp adjust-mss 1360
ip summary-address eigrp 100 10.102.73.0 255.255.255.0 5
keepalive 20 3
tunnel source Loopback2
tunnel destination 172.31.0.6
end
interface Tunnel2
description GRE VPN2 Secondary Tunnel
bandwidth 384
ip address 10.99.133.54 255.255.255.252
ip mtu 1400
delay 50010
keepalive 20 3
tunnel destination 172.31.0.10
end
interface Tunnel3
description GRE VPN3 Backup Tunnel to Secaucus
bandwidth 256
ip address 10.99.69.54 255.255.255.252
ip mtu 1400
delay 100000
keepalive 20 3
tunnel destination 10.5.251.12
end
Richard Burts
This router has 2 subnets as local connected subnets within this address space. Rather than advertise the individual subnets the router has configured the summary address command on the tunnel interfaces. The result is that the router advertises one summary instead of the individual subnets. And when summarization is configured EIGRP will install a route for the aggregate with null 0 as the next hop.
Rick
Rick
Richard Burts
Rick
Rick
I am glad that my explanation was helpful. Thank you for using the rating system to mark this question as answered. It makes the forum more useful when people can read a question and can know that an answer was found. Your marking has contributed to this process.
Rick
Rick
