07-27-2018 01:54 AM
I have a remote site connected via a series of Metro Ethernet links with EIGRP routing configured.
I now created a GRE tunnel over IPSEC over an internet link as a backup path.
MAIN SITE .................................................................................. REMOTE SITE
routerA <-ethernet-> routerB <-ethernet-> routerC <-ethernet-> router1
routerX <---------- GRE over IPSEC tunnel ----------------> router2
My problem is when I enable eigrp on the GRE tunnel interfaces it takes over the routes learned over the main path and poises my whole routing, even though the metric is much higher.
The router marks the tunnel bandwidth with a low value and I even increased the delay so this shouldn't happen.
Router2 Tunnel interface configuration:
interface Tunnel10
ip address 172.29.19.133 255.255.255.252
 ip mtu 1400
 ip tcp adjust-mss 1340
 delay 9999900
 tunnel source Loopback10
 tunnel destination Y.Y.Y.Y
router eigrp 100
 network x.x.x.x
 network z.z.z.z
 redistribute connected
 passive-interface default
 no passive-interface GigabitEthernet0/0/0.10
 no passive-interface GigabitEthernet0/0/0.40
 no passive-interface tunnel10
#sh int tunne10
Tunnel10 is up, line protocol is up
 Hardware is Tunnel
Internet address is 172.29.19.133/30
 MTU 9976 bytes, BW 100 Kbit/sec, DLY 99999000 usec,
 Encapsulation TUNNEL, loopback not set
 Keepalive not set
 Tunnel linestate evaluation up
 Tunnel source 172.29.19.129 (Loopback10), destination Y.Y.Y.Y
 Tunnel Subblocks:
 src-track:
 Tunnel10 source tracking subblock associated with Loopback10
 Set of tunnels with source Loopback10, 1 member (includes iterators), on interface <OK>
 Tunnel protocol/transport GRE/IP
 Key disabled, sequencing disabled
 Checksumming of packets disabled
 Tunnel TTL 255, Fast tunneling enabled
 Tunnel transport MTU 1476 bytes
 Tunnel transmit bandwidth 8000 (kbps)
 Tunnel receive bandwidth 8000 (kbps)
Here's an example of a route on Router2 when EIGRP is disabled on the tunnel, it is pointing to router1 via the lan interfaces, which is correct:
Router2# sh ip route 172.30.40.0
Routing entry for 172.30.40.0/24
 Known via "eigrp 100", distance 90, metric 29440, type internal
 Redistributing via eigrp 100
 Last update from 172.29.14.2 on GigabitEthernet0/0/0.40, 00:00:36 ago
 Routing Descriptor Blocks:
 * 172.29.14.2, from 172.29.14.2, 00:00:36 ago, via GigabitEthernet0/0/0.40
 Route metric is 29440, traffic share count is 1
 Total delay is 150 microseconds, minimum bandwidth is 100000 Kbit
 Reliability 255/255, minimum MTU 1500 bytes
 Loading 1/255, Hops 5
 172.29.11.2, from 172.29.11.2, 00:00:36 ago, via GigabitEthernet0/0/0.10
When I enable eigrp on the tunnel it takes over even though the distance is the same and the metric is much higher:
 Known via "eigrp 100", distance 90, metric 2585574912, type internal
 Last update from 172.29.19.134 on Tunnel10, 00:01:08 ago
 * 172.29.19.134, from 172.29.19.134, 00:01:08 ago, via Tunnel10
 Route metric is 2585574912, traffic share count is 1
 Total delay is 99999020 microseconds, minimum bandwidth is 100 Kbit
 Reliability 255/255, minimum MTU 1400 bytes
 Loading 255/255, Hops 2
Any thoughts?
07-27-2018 03:49 AM
Interesting and my compliments on providing all the pertinent information. Could be a bug, but what does the route look like in R1 when the tunnel is up? Also, with the tunnel up, is RA still advertising it to R1?
07-27-2018 04:00 AM
Hi thanks for replying
With the tunnel up R1 learns the routes via R2 and RC from R1.
RA is still announcing and RB is getting them correctly.
RouterA <-eth 1Gbps-> RouterB <-eth 100Mbps-> RouterC <-eth 100Mbps-> Router1
07-27-2018 04:08 AM
I'm leaning towards it being a bug, but could you post the output of "sh ip eigrp topology 172.30.40.0/24" with the tunnel active?
07-27-2018 05:29 AM
in addition to the other posts, post the full configurations of all six routers so we can lab this...
07-28-2018 08:15 AM
Most likely recursive loop is created since you are advertising tunnel endpoints through tunnel. Route to tunnel endpoint should not point to tunnel (need to point to wan interface). Can be achieved by filtering tunnel endpoints with distribution list, or static route.
07-29-2018 03:00 AM - edited 07-29-2018 03:01 AM
Hello
why don’t you NOT advertise the gre tunnel and just policy route over it the subnets you wish to traverse it
or
create a different eigrp or routing process and advertise it over that?
