Strang Router Behavior
htimskinorbit
I have 2900 series legacy router being configured for small office environment with a single ISP connection, and are assigned a single IP address.  I am using 10.0.0.0 network address space sent to a ASA5540 to use PAT with the ASA's outside interface address.   On the router, I have configured the most basic config possible, and ping'd the local interfaces successfully but it cant ping the directly connected neighbors interfaces on the directly connected networks.  No (default)routes are needed to ping interfaces on directly connected networks, the router knows were they are, they're directly connected.  Both device IP's on the respective connected networks have the same subnet mask, so they have the same 'view of the world', ie - to prevent the problem of the ping goes out but can't get back.  From the config below....   On Gi0/1, I should be able to ping any directly connected neighboring device in the range of 10.10.0.1 - 10.10.255.254, which is the directly connected network, but can't.   On Gi0/0, I should be able to ping any directly connected device with IP's from, 10.20.0.2 - 10.20.255.254, but can't ping any.  I am not an expert, but this is a very basic config. Assign some IP addresses/masks to interfaces, enable IP routing and you should at least be able to ping the local IP's and any on a directly connected subnet. The router config was wiped and started fresh adding the few items I described.
! Last configuration change at 03:01:47 UTC Thu Jul 26 2018
version 15.1
hostname Router
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
no aaa new-model
no ipv6 cef
ip source-route
ip cef
no ip dhcp conflict logging
ip dhcp excluded-address 10.20.0.0 10.20.0.128
ip dhcp pool LAN-Ip's
   network 10.20.0.0 255.255.0.0
   domain-name My_Domain_Name
   default-router 10.20.0.1
   dns-server 208.67.222.222 1.1.1.1 8.8.8.8
no ip domain lookup
voice-card 0
hw-module pvdm 0/0
redundancy
interface GigabitEthernet0/0
 ip address 10.20.0.1 255.255.0.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 10.10.10.2 255.255.0.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
!gatekeeper
 no shutdown
line con 0
 logging synchronous
line aux 0
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
johnd2310
Level 8
Level 8
hi
What is connected to Gi0/0 and Gi0/1? What do you get if you run "show ip  arp " on the router.
John
**Please rate posts you find helpful**
Predrag Jovic
Level 3
Level 3
Can you,  please, check routing table and interface status.
show ip interface brief
show ip route
If routing table is present and interfaces are in up up state my guess would be that issue may be:
- cable swap between Gi0/0 and Gi0/1
- port configuration of connected device(s) (port configured as trunk instead of access)
- something similar to the above
Otherwise device may be faulty.
Hello
1)does this rtr have ip routing enabled?
2) do the connected clients have the correct subnet and default-gateway applied
(note - gateway only needed for inter vlan communication and wan access)
3) do these clients have any software Fw applied to them negating echo reply
4) if these interfaces are connected to a switch are the related access ports in the correct vlan
5) as stated by others what does the arp table show
res
paul
Kind Regards
Paul
