EIGRP with DMVPN and more then 300 Sites
gauravbisht
Hi Experts,
About Network
We are using HUB & SPOKE topology with DMVPN and over it we are running EIGRP
HUB Hardware : Cisco 3945E
HUB Bandwidth : 50 Mbps
Spoke Hardware : Cisco 1921
Spoke Bandwidth : Min 5M, Max 50M depends on site to site
Total Spoke sites : 300+
Issue :
We are getting following message, but fraction of seconds Tunnel 0 is comming UP again
Sep  3 22:40:26.513 CST_-DS: %DUAL-5-NBRCHANGE: EIGRP-IPv4 666: Neighbor 10.119.253.1 (Tunnel0) is down: Peer Termination received
Sep  3 22:40:30.649 CST_-DS: %DUAL-5-NBRCHANGE: EIGRP-IPv4 666: Neighbor 10.119.253.1 (Tunnel0) is up: new adjacency
Troubleshooting :
To identify connectivity we have created two IP-SLA for
1 IP-SLA is pinging HUB Tunnel 0 interface
2 IP-SLA is pinging some Public IP which is 100% available or Service Provider IP
Point 1: We are getting Drops in IP-SLA 1, but this is not happening in all site, only on few sites
Point 2: We are not getting any Drop on IP-SLA 2 it mean Internet link is OK at SPOKE site
Point 3 : On HUB Site, we don't have IP-SLA but in "sh ip eigrp neighbor" we can see many neighbors which are UP from more then 2 weeks
Observed following things
Tunnel0 is up, line protocol is up
  Hardware is Tunnel
  Internet address is 10.10.10.1/22
  MTU 17912 bytes, BW 50000 Kbit/sec, DLY 10000 usec,
     reliability 255/255, txload 255/255, rxload 90/255
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source X.X.X.X (GigabitEthernet0/1)
   Tunnel Subblocks:
      src-track:
         Tunnel0 source tracking subblock associated with GigabitEthernet0/1
          Set of tunnels with source GigabitEthernet0/1, 1 member (includes iterators), on interface <OK>
  Tunnel protocol/transport multi-GRE/IP
    Key 0x6C8FA, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1472 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "cvo-profile")
  Last input 00:00:00, output never, output hang never
  Input queue: 0/75/176340/0 (size/max/drops/flushes); Total output drops: 4677116
  Queueing strategy: fifo (QOS pre-classification)
  Output queue: 0/0 (size/max)
  5 minute input rate 17758000 bits/sec, 17344 packets/sec
  5 minute output rate 96109000 bits/sec, 22772 packets/sec
     1599976943 packets input, 651583349 bytes, 0 no buffer
     Received 0 broadcasts (19 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     2435946192 packets output, 504893206 bytes, 0 underruns
     0 unknown protocol drops
Can anyone help to identify the cause of EIGRP neighborship drop on this setup, this is only happening on few sites, not on all site
Hello
are you using multicast or uni cast nhrp peering?
if multicast is this being allowed on hub and spoke
Spoke
int tun x
ip nhrp map multicast (nbma hub )
res
paul
Kind Regards
Paul
