EIGRP
dangal.43
EIGRP is the hybrid routing protocol right so we can classify it in both the class distance vector and link state is that right?
mparekh
Level 3
Level 3
According to the link below EIGRP is a disctance vector protocol with link state capabilities and features.
http://www.cisco.com/en/US/tech/tk1330/tsd_technology_support_technical_reference_chapter09186a00807598ad.html
rocking in summury they have mention that its robust Distance vector protocol.
Another thing to bear in mind is EIGRP is Cisco Proprietary and if you are looking to run a distance vector protocol in a multi-vendor environment RIP will be your protocol of choice.
Sundar
