Email notifications stopped working after adding 2nd ISP
Darren Spezio
 e-mail notifications and scan to e-mail from the copiers stopped working after adding second ISP using NATing, both use aspmx.l.google.com, regular e-mail communcation between users work fine.
ISP was added for additional bandwidth. As soon as I remove the 2nd IP route, the email notifications and scan to email start working again.
Cisco 2900
interface GigabitEthernet0/0
description Outside-LightPath
ip address 173.x.162 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
description To Firewall
ip address 69.x.209 255.255.255.240
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 108.x.146 255.255.255.252
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 50 interface GigabitEthernet0/2 overload
ip route 0.0.0.0 0.0.0.0 173.x.161
ip route 0.0.0.0 0.0.0.0 108.x.145
access-list 50 permit 69.x.211
no cdp run
control-plane
banner motd ^C
This equipment is privately owned & operated.
It is for AUTHORIZED USE ONLY!
All access to this equipment is logged.
DISCONNECT IMMEDIATELY if you are not an AUTHORIZED User.
Violators will be prosecuted to the fullest extent of the law.
^C
line con 0
login local
line aux 0
line vty 0 4
login local
transport input ssh
scheduler allocate 20000 1000
ntp server 128.118.25.5
end
10 Replies 10
Hello
On the second additional interface you don't have nat applied and with the additional default route you are now load sharing  between the two ISPs and probably incurring asymmetric routing.
if you would like to dual nat between the two ISPs I would suggest using route-maps in your nat configuration
Config t
int gig0/0
ip nat  outside
route-map ISP1
match IP address 50
match interface gig0/0
route-map ISP2
match IP address 50
match interface gig0/2
no ip nat inside source-list 50 interface gig0/2
ip nat inside source route-map ISP1 interface gig0/0 overload
ip nat inside source route-map ISP2 interface gig0/2 overload
Res
Paul
Kind Regards
Paul
Do I just add these to each interface or globally?
Does anything need to be removed from the current config?
Darren
Hello
i have edited my OP so you should be able to copy and paste the config but please note applying on a existing production router
Please go through your agreed sla change control
res
paul
Kind Regards
Paul
I will give this a try tomorrow during non production hours. I have a couple of quick questions.
1. I'm not sure I understand "go through your agreed sla change control"
2. What does "match ip address 50" represent? what does it look to?
Hello
Make sure you have authorisation from  you place of work to implement any changes.
This matches on your existing access-list 50 relating to your lan facing interface of the router your querying -
Please note: -  If you have limited experience in networking please do NOT implement any changes to your live network you are not comfortable with or not fully aware of the consequences yours changes may incur and most importantly not able to back out from.
res
Paul
Kind Regards
Paul
I will make a backup copy of the current config and make these changes during non-production hours. Looks pretty straight forward, unless I'm missing something.
This message came up when removing "no ip nat inside source-list 50 interface gig0/2"
 Dynamic mapping in use, do you want to delete all entries? yes no
Okay, everything is entered, how do I check if I now have symmetrical routing taking place?
Okay our external Public IP address changed to 173.x.162 from 69.x.x.211 for that ISP circuit.
Also our IP forwarding stopped working i.e. 69.x.x.212 to internal server 10.8.x.x
pinging...
