'Embedded RP on IPv6' + System received a SegV exception
ruizzito
Hi.
I try to configure de folloing scenary - Embedded RP with IPv6
I used 3 cisco 2600 routers:'Cisco IOS Software, C2600 Software (C2600-ADVENTERPRISEK9-M), Version 12.4(5), RELEASE SOFTWARE (fc3)'
For cliente and server streamnig, i used Videolan-Client
I have end-to-end conectivity - in R1 i can ping sucessefully 2001:ddd::1
In R2, i have configured de serial0/1 with: IPv6 address 2001:ccc:beef:feed::1/32
in the same router, R2, i configured: 'ipv6 pim rp-address 2001:CCC:BEEF:FEED::1'
all routers have enable embedded rp: 'IPv6 pim rp embedded'
but when i put VLC to stream at address [FF76:140:2001:CCC:beef:feed::1], the cisco IOS reboot...
What is a problem?? bug in IOS, bad configurations??
i really apreciate you help
thanks in advanced.
thansk, Rui Bernardo
2001:AAA::/32.....2001:BBB::/32.....2001:CCC::/32.....2001:DDD::/32
PC1--- .1[ R1 ].1---serial----.2[ R2 ].2---serial-----.1[ R3].1-----PC2
.....eth0.....ser0/1.....ser0/0.....ser0/1.....s0/0..... eth0/0
R1 con0 is now available
Press RETURN to get started.
15:51:59 UTC Mon Mar 4 2002: Unexpected exception to CPUvector 1200, PC = 0x814D7104, LR = 0x814D70E4
-Traceback= 0x814D7104 0x81F6CDB8 0x819528D8 0x81952914 0x827F6384 0x827F72C8 0x827E2C94 0x827E2EE8 0x827DB198 0x8280D6F0 0x8280D880 0x827DB8E4 0x8280CAF8 0x8280CCE8 0x827CC06C 0x827CB754
CPU Register Context:
MSR = 0x00009032 CR = 0x30009009 CTR = 0x806FAF98 XER = 0x80001C7F
R0 = 0x00000030 R1 = 0x85D5E0D0 R2 = 0x84AD0000 R3 = 0x00000001
R4 = 0x851AE3A0 R5 = 0x851AE1D4 R6 = 0x00000001 R7 = 0x68010000
R8 = 0x00009032 R9 = 0x00000000 R10 = 0x68010000 R11 = 0x84C10000
R12 = 0x02147698 R13 = 0xFFF4B634 R14 = 0x8519F1A8 R15 = 0x00000000
R16 = 0x84C9DBE4 R17 = 0x00000000 R18 = 0x84ED1C1C R19 = 0x84390000
R20 = 0x84390000 R21 = 0x84ED0000 R22 = 0x00000000 R23 = 0x00000590
R24 = 0x85417140 R25 = 0x00000001 R26 = 0x00000560 R27 = 0x00000024
R28 = 0x074050D8 R29 = 0x85D42318 R30 = 0x84FD18FC R31 = 0x84FD18FC
Writing crashinfo to flash:crashinfo_20020304-155159
=== Flushing messages (15:51:59 UTC Mon Mar 4 2002) ===
Queued messages
*** System received a SegV exception ***
signal= 0xb, code= 0x1200, context= 0x84e24818
PC = 0x814d7104, Vector = 0x1200, SP = 0x85d5e0d0
System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
Copyright (c) 2003 by cisco Systems, Inc.
C2600 platform with 131072 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x1c413c0
Self decompressing the image : ##########
spremkumar
Level 9
Level 9
SegV exceptions are mostly turned as a S/W (IOS) related issue..
Also the notable possible reasons for the same are
1)Access to an invalid memory address
2)Write access to a read-only memory region
3)A jump to an invalid PC (often 0x0)
would also suggest to check this link if u havent seen this earlier..
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a0080189ddb.shtml
regds
