NAT issue
seegomaa
dears
i want to replace the destination addres of a packet by another destination , if that possible i want to have sample of configuration ( i have router 3640
pkhatri
Level 11
Level 11
Try the following:
interface
ip nat inside
interface
ip nat outside
ip nat outside source static
Also be sure that you have a route to the external(NATTED) address on your router or this will not work.
Paresh
mheusinger
Level 10
Level 10
you can use the "ip nat inside destination" command.
Have a look at
"Cisco IOS Network Address Translation Overview"
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_white_paper09186a0080091cb9.shtml
or at
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a0080238b73.html#wp1164300
Hope this helps
Martin
