Enable firewall-logging (877)
Alain Cloet
Community Member
Is there a way to enable logging (to a SysLog host) for all firewall-functionality on a Cisco 877 ADSL router ?
I did some setup using SDM-express, but this doesn't give any SysLog-messages for passed or failed connections. It should be possible by modifying some of the zone-security with "pass log" en "drop log", but isn't there a way to get all logs either when it pass or failed ?
And if so, which commands should I add ?
Alain
mchin345
Level 11
Level 11
Enable or disable syslog and SNMP logging. (Configuration mode.)
logging on
no logging on
You can filter generated system log messages so that only certain system log messages are sent to a particular output destination.
