Enable HSEC license on C1111 Router
rasmus.elmholt
Level 7
Level 7
I have a C1111 Router where I have bought it with the HSEC license.
But I am not able to figure out how I will install it. When I look at the license it seems like it is not installed.
R2#show ver
Cisco IOS XE Software, Version 17.06.03a
Cisco IOS Software [Bengaluru], ISR Software (ARMV8EL_LINUX_IOSD-UNIVERSALK9-M), Version 17.6.3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Fri 08-Apr-22 12:42 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2022 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: (c)
R2 uptime is 27 minutes
Uptime for this control processor is 28 minutes
System returned to ROM by Reload Command at 15:21:53 CEST Tue Jun 20 2023
System restarted at 15:23:47 CEST Tue Jun 20 2023
System image file is "bootflash:packages.conf"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  Smart License  None
securityk9
appxk9
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           appxk9           Smart License    appxk9
uck9             uck9             Smart License    uck9
securityk9       securityk9       Smart License    securityk9
ipbase           ipbasek9         Smart License    ipbasek9
The current throughput level is unthrottled
Smart Licensing Status: Registration Not Applicable/Not Applicable
cisco C1111-8P (1RU) processor with 1398054K/6147K bytes of memory.
Processor board ID FCZ*********
Router operating mode: Autonomous
3 Virtual Ethernet interfaces
10 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
2945023K bytes of flash memory at bootflash:.
R2# show licen sum
License Usage:
  License                 Entitlement Tag               Count Status
  throughput              (ISR_1100_8P_IPSEC_Thro...)       1 IN USE
  appxk9                  (ISR_1100_8P_Application)         1 IN USE
  uck9                    (ISR_1100_8P_UnifiedCom...)       1 IN USE
  securityk9              (ISR_1100_8P_Security)            1 IN USE
OrlandoGM
Hello @rasmus.elmholt,
What the HSEC license does on your router is to unthrottle the IPSec traffic to its maximum. When issuing the show license summay  command, you can see:
 And also:
 I would assume it's enabled already.
Cheers.
Orlando González.
