Enable pinging WAN IP from ethernet clients
GovanJ221
Hello
I'm trying to enable access to web servers and other things from the lan using the WAN IP,
Currently pinging the wan ip does not reply.  External access to the resources is working correctly.
any help would be really appreciated. Thanks
You could try using NAT virtual interface (NVI).  Instead of having the concept of inside and outside, you only enable NAT on the interface.
Interface BVI1
  ip nat enable
interface Dialer0
  ip nat enable
ip nat source static tcp 192.168.0.100 25 80.159.38.225 25
Notice you remove "inside" from "ip nat inside source..."
5 Replies 5
Richard Burts
James
Your question is not clear to me. When you say:" enable access to web servers and other things from the lan using the WAN IP" I am not clear whether the lan you refer to is the lan where the servers exist (in which case the communication would be direct and not involve the router) or whether the lan is remote somewhere. And if it is remote where is it?
It is also not clear what part the WAN IP plays in this.
You have not told us anything about the addressing being used (which could be part of the problem), you have not told us whether there is any access list filtering on either the interface where the servers are located or the WAN interface (which could certainly be part of the problem), or it could be a problem with routing (do the devices attempting to access the servers have correct routes to reach the servers or do the servers have routes to those devices so that responses can be returned), or it could possibly be a problem with Address Translation (which could also be part of the problem).
So if you can provide information to clarify the situation we might be able to give you better answers.
Rick
Rick
Thanks for the reply. I'll try to expain it a little better.
We have a server with IP 192.168.0.100
Its accessible within the LAN using its local IP address and from the outside using the global ip. Thats not a problem
The problem is that the applications on the clients are configured to access the server using the global ip address but that is not accessible from within the LAN.
is there someway to loop these requests back?
here's my config if it helps, thanks again:
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
no logging on
enable password 010101
no aaa new-model
clock timezone PCTime 0
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
dot11 ssid test test test
authentication open
guest-mode
no ip source-route
ip dhcp excluded-address 192.168.0.1 192.168.0.3
ip dhcp excluded-address 192.168.0.99 192.168.0.101
ip dhcp pool mypool
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 8.8.8.8 8.8.4.4
ip cef
no ip bootp server
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no snmp trap link-status
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
bridge-group 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no shut
ssid test test test
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
bridge-group 1
interface Dialer0
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname xxxxxx
ppp chap password 0 xxxxxx
ppp pap sent-username xxxxx.net password 0 xxxxx
interface Dialer1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
interface BVI1
description $ES_LAN$
ip address 192.168.0.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 192.168.0.100 25 80.159.38.225 25 extendable
ip nat inside source static tcp 192.168.0.100 81 80.259.38.225 81 extendable
ip nat inside source static tcp 192.168.0.100 1352 80.259.38.225 1352 extendable
ip nat inside source static tcp 192.168.0.100 8889 80.259.38.225 8889 extendable
ip nat inside source static tcp 192.168.0.101 10996 80.259.38.225 10996 extendable
ip nat inside source static tcp 192.168.0.100 25017 80.259.38.225 25017 extendable
ip nat inside source static tcp 192.168.0.99 58000 80.259.38.225 58000 extendable
access-list 1 permit 192.168.0.0 0.0.0.255
dialer-list 2 protocol ip permit
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
exec-timeout 0 0
no modem enable
speed 115200
line aux 0
line vty 0 4
password 010101
login
scheduler max-task-time 5000
end
Interface BVI1
  ip nat enable
interface Dialer0
  ip nat enable
Thanks very much,. That seems to resolve the issue. Been pulling my hair out.
Thanks again all
Maybe you could try this solution: don't connect directly to IP address - connect to the hostname (FQDN). And make sure your (split-brain) DNS is configured correctly.
