Enabling https for SDM in cisco 2811 router
csaravanan
I am having cisco 2811 router running IOS 12.3(8r). I am currently accessing SDM through http method. I wanted to access it through https and disable http method.
What procedure should I follow
Chandru
You need an IPSec IOS image to enable https server on your router.
Sundar
5 Replies 5
Chandru,
I believe the commands you need are,
From config mode:
no ip http server
ip http secure-server
Check out this link for more info:
http://www.cisco.com/en/US/products/ps5854/prod_configuration_guide09186a00802c35f5.html
Sundar
The problem is I am not getting the ip http secure-server option.
Router(Config)#ip http ?
The output is
access-class
authentication
client
max-connections
path
port
server
time-out policy
I could not also generate rsa keys
Most likely you aren't running an image that supports crypto, could you paste in a 'show version' so we can see which feature set you're running?
Sundar
Thanks Sundar, Thanks Wochanda. I am not running an IPSec IOS image. Its an regular Routing IOS image.
