Enabling IPSEC 3DES in PIX 515E
Danilo Dy
I have this PIX 515E (HA) with IPSEC 3DES disabled. How should I enable it? Should I need an activation key to enable it? Do I need to purchase it? What's the impact in a production firewall if I load a new activation key? How should I load it?
TIA
Jon Marshall
Hi Danilo
You can register for a free 3DES license from Cisco. Go to this link
(you need a login but i'm assuming you have one ?)
http://www.cisco.com/kobayashi/sw-center/ciscosecure/pix.shtml
You will get a new activation key. You can load it on a production system without impact but you need to do a reboot for it to take effect.
Jon
Jon Marshall
Hi Danilo
Jon
Hi Jon,
Thanks for the link. I'm able to generate activation key for 3DES. I haven't installed it yet as it needs downtime according to this document http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00806b1c0f.shtml but you point me to the right direction.
Dandy
