Enabling IPsec Tunnel on Cisco ASR 1000 router
Va.8427
Hi there.
We have 2 ASR 1001-HX routers. I've tested 3 different versions of IOSxe in order to enable securityk9 Right-to-Use license, but there was no result.
Currently active boot system image :
asr1000-universalk9.16.06.04.SPA.bin
previous images I've tested :
asr1000-universalk9.16.06.03.SPA.bin
asr1000-universalk9_noli.16.05.01b.SPA.bin
some benefit show command results and information you may want to know
Router#sho ver | in absent
Crypto Hardware Module absent
Feature name             Enforcement  Evaluation  Subscription   Enabled  RightToUse
securityk9                  yes                 yes           no                   no          yes
ipsec                         yes                 yes           no                   no          yes
These commands have been executed
license accept end user agreement
license solution level securityk9
license right-to-use move securityk9
license right-to-use move ipsec
Router#sho license right-to-use
Index 19 Feature: ipsec
              Period left: Life time
              License Type: RightToUse
              License State: Active, Not in Use, EULA accepted
              License Count: Non-Counted
              License Priority: Low
Index 33 Feature: interface_10g
             License State: Active, In Use
             License Count: 1/0 (In-use/Violation)
Index 36 Feature: securityk9
Router#
I will be so appreciated if anybody can help me.
sounds like you are using the right commands. The fastest way to resolve this is probably to contact the Global Licensing Team:
https://slexui.cloudapps.cisco.com/SWIFT/LicensingUI/html/contact.html
