Redistribute BGP/OSPF route map xxxx
Pierre2018
Hello Team,
We have a route Map « FROM_TEST1» configured to filter a BGP route under OSPF.
We have detect that this subnet «192.168.1.2/24» is appear in the routing table , Which is not normal for us.
SW#sh run | s router
router ospf 21 vrf DATA
log-adjacency-changes
redistribute bgp 65000 subnets route-map FROM_TEST1
network xxxxx
SW#sh ip route vrf DATA 192.168.1.2
Routing entry for 192.168.1.2/24
Known via "bgp 65000" distance 20, metric 0
Tag 642, type external
Redistributing via ospf 20
Advertised by ospf 20 subnets route-map FROM_TEST1
SW#sh ip ospf 21 database | i 192.168.1.2
192.168.1.2 10.206.4.1 987 0x80004E88 0x004CB1 3489726128
192.168.1.2 10.206.4.10 084 0x80004E86 0x004AB4 3489726128
kind Regards,
2 Accepted Solutions
Alex Pfeil
Level 7
Level 7
Please provide the route-map and ACLs.
Hello
@Pierre2018 wrote:
Thank you for your assistance.
How i can change it !!
route-map FROM_TEST1 permit 10
no match ip address TEST1
match ip address prefix-list TEST1
Kind Regards
Paul
9 Replies 9
Alex Pfeil
Level 7
Level 7
bellow the ACL and Route Map:
ip prefix-list TEST1 seq 5 permit 10.206.2.200/32
ip prefix-list TEST1 seq 10 permit 10.206.3.230/32
Why i see this subnet "192.168.1.2" in the ospf database, however that not permitted in the ACL !!
Thank you very Much.
Kind Regards,
You have a prefix-list configured and you are trying to match an ACL in the route-map. You have to change the match statement to be a prefix list or write an ACL to match.
when trying to match an IP, use the match up address prefix-list command.
thanks,
alex
Match IP address prefix-list. Spellcheck changed it above.
hi,
Thank you Alex,
It's normal to see this subnet in the OSPF database table.
BR,
Hello
the reason why your seeing that prefix is the redistributed route-map isnt be matched on your prefix-list so it’s advertising everything as per default when an empty route- map is specified
As as already stated ammend your route-map to match on prefix—list instead of an acl
Kind Regards
Paul
Paul’s explanation is sufficient. Your existing prefix-list is not working and is permitting all routes. The resolution is to change the route-map to match the prefix-list.
Please rate helpful posts.
thanks,
Alex
Thank you
BR,
Hello
Kind Regards
Paul
