Enabling RITE on the 7206VXR-NPE-G2 router
nadeem-akhtar
I need to enable RITE (Router IP Traffic Export) on a 7206VXR router running 12.4(15)T5 on an OC3 interface. How much should I be concerned about CPU utilization? Any other concerns? This is not for IDS. Where else can I have the capture besides ISR routers? Can a regular netflow collector capture traffic in this scenario? How is RITE different from NetFlow?
Nadeem
Giuseppe Larosa
Hello Nadeem,
Netflow classifies flows and exports information on observed flows, RITE attempts to export captured data (packets)
Depending on your needs netflow can be enough.
Also if you look at
http://www.cisco.com/en/US/partner/docs/ios/12_4t/12_4t11/ht_rawip.html
or
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/ht_rawip.html
you can see the following limitations:
RITE export is done at L2 level the destination is actually a MAC address of a device in the same IP subnet of the exporting interface.
the document says RITE is supported only on ISR routers, C7200 is not mentioned
So RITE can be useful as an OSI L2 converter:
to capture data on a serial interface for example and to send them to a laptop with a protocol analyzer running on it.
Netflow export is IP based and can be sent to a collector server that is several hops away.
Even if C7200 supports it the cpu load for capturing traffic on an Oc-3 link can be high, there is an option to use ACLs to make a selective capture.
Hope to help
Giuseppe
Thank you very much Giuseppe. It did help.
