Encapsulation failure on Ethernet WAN Link
phil_carter
A new BT cct across a Riverstone network has been provisioned with 2 cisco devices are at each end. The link has physically come up at both ends, but OSPF will not form across the link. More worryingly I can't ping across the link either. I can see OSPF packets being sent out at each end....
Debugging IP packets on the remote end while trying a ping across the WAN link, I get the below reported:
Jan 13 09:03:56: IP: tableid=0, s=10.4.231.37 (local), d=10.4.231.38 (FastEthern
et0/1), routed via RIB
Jan 13 09:03:56: IP: s=10.4.231.37 (local), d=10.4.231.38 (FastEthernet0/1), len
100, sending
100, encapsulation failed <<<<<
Can anyone advise further as to why this is reporting this?
Phil
Giuseppe Larosa
Hello Phil,
from the symptoms you describe there isn't real connectivity between the two sites.
encapsulation failure means that failing ARP the frame cannot be sent out not knowing the destination MAC address.
you can check this also with:
sh ip arp 10.4.231.38
if you see incomplete means ARP process fails and this means connectivity is not good.
You see interface up/up but the L2 transport service is not working properly
contact the service provider
Hope to help
Giuseppe
Giuseppe Larosa
Hello Phil,
Hope to help
Giuseppe
