Enforce-as-first disable config Causing Route Leak @ Internet exchange
Belinda Afari
 Hello, The ISP I work for is having challenges with implementing the enforce-as-first disable configurations with an internet exchange. We have an RR setup for our BGP core. This command has been successfully applied to our Internet exchange connection on our upstream RR server routers. The new implementation is on one of our RR clients where the exchange is located. NB: as-path filters have been applied at the new exchange and all works fine until the configuration of the enforce-as command.
Any suggestions on a probable cause and solution?
I review and make second review to your issue
now I think that even if the first AS in AS-PATH is ignore still the NEXT-HOP issue,
the BGP first criteria is NEXT-HOP reachable
if it reachable then the path is accept
if not reachable then the path is reject
so TRY
neighbor x.x.x.x route-map NEXT in
route-map NEXT permit 10
match ip address  <<- this optional you will apply route-map first for only one prefix if success then we can apply it to all other prefix.
set ip next-hop peer address
for IOS XR
 route-policy NEXT
set next-hop peer-address
