Enquiry: For vrf leaked routes what should be the origin in BGP
inderjeet452
Hi All,
I stucked in some issue, let say we are having two vrf and done the route leaking between these two.
In one vrf when we check the bgp table it is showing origin(i) for all networks.
After done the leaking when we check the same in other vrf, the origin code changed to (?).
Is this fine or any issue with the leaking or RFC standard?
Thanks MHM for the output.
So if we leak something in vrf it's origin will not be changed.
This behaviour is vendor specific or it is a standard that other vrf route showing origin as (i) will not change it's origin (i) after import/export.
And if this is the standard it should not change the origin please share link to go through the same.
Thanks in advance.
7 Replies 7
Pedroxh
Hi. Is fine. The origin code "?" n the BGP means when you have redistributed something into BGP.
Best regards
******* If This Helps, Please Rate *******
My question is
Suppose I am using two vrf
VRF-A and VRF-B
When I check
show ip bgp vrf A
for those networks I announced in BGP via
NETWORK
command showing origin code as (i) and same for different vrf B as well.
Now I import/export both vrf and when checked the
show ip bgp vrf A
it showing vrf B network origin code as (?) While in same vrf is was originating via (i). How it can changed to (?).
Any prefix that inject into bgp via
network have "" i""
Any other since router inject ot unknown it will have ""?"" Included prefix that redistrubte.
Thanks for the response.
Here I am taking about vrf routes which are imported/exported.
The network which shows as (i) in vrf A and when we import this vrf A to vrf B, whether the origin will change or with same origin code it will imported and shows in bgp vrf table.
I un lab and test the modify of origin,
there is no modify.
the R2
advertise 22.22.22.22
origin IGP (using
network
command) the prefix show in VRF RED and BLUE and R3 as origin IGP.
no modify.
Thanks in advance.
Can anyone refer any standard for the subjected discussion.
