EoMPLSoGRE on ASR1002
patrickg
I want to run EoMPLSoGRE between 2 data centers terminating the GRE and pwire on the ASR. Couple of questions: 1) Are there any special requirements on the ASR to support this? 2) Any caveats with running this in this manner?
My first hop is L3 with my provider and hence the need to run EoMPLSoGRE. Thanks for your help.
Giuseppe Larosa
Hello Patrick,
I see you got a good answer in MPLS forum by Laurent
(just to remove this from unanswered threads list)
Best Regards
Giuseppe
