Showing results forĀ
Search instead forĀ
Did you mean:Ā
equivalent command for alarm display
cisco-blue
what is the logical equivalent commad for checking the alarm  physically,
in 2811 , 1841 & 7609 seris
is facility-alarm works fine for this
Rick Morris
Level 6
Level 6
What are you trying to look at?
Are you looking for status of equipment, fans, cpu, memory, etc... or are you looking for IDP or other security alarms?
in the aboe routers 2811,1841,7609 series
i have to give the command hw-module slot (slot no> reload
and that alrm we have to verify through  command
