ERASE START UP CONFIG XR
pramod
How to erase the startup config of an XR device?
6 Replies 6
Leo Laohoo
In enable mode: wr er
write erase command wont work on XR devices
Rick Morris
Level 6
Level 6
When you are in enable mode, or exec depending on what you call it, if you type erase what are your options?
I believe your option would be erase startup-config
xthuijs
go into configuration mode in ios-xr
make a small change such as "no hostname"
do
commit replace
that will wipe out the entire config.
Akhileshpk_2
What is your hardware platform?
Please try the following commands after removing the standby RP:
          commit replace
          commit replace best-effort
Do not forget to create a user before reloading the router as given below:
RP/0/RSP0/CPU0:ios(config)#username abc
RP/0/RSP0/CPU0:ios(config-un)#secret abc123
RP/0/RSP0/CPU0:ios(config-un)#group root-system
RP/0/RSP0/CPU0:ios(config-un)#commit
Please revert .... !!!
Akhil
