Error de interfaz serial CRC,frame, overrun
yesica
buenos Dias, comunidad
solicito de su apoyo para entender el error que me genera la interfaz del router es un servicio de internet de texto , actualmente no tengo servicio.
INT-3830# show ip int se0/0/1
Serial0/0/1 is up, line protocol is up
Internet protocol processing disabled
INT-3830# show inte se0/0/1
Hardware is GT96K Serial
MTU 1500 bytes, BW 2048 Kbit/sec, DLY 20000 usec,
Encapsulation FRAME-RELAY, loopback not set
Keepalive set (10 sec)
CRC checking enabled
LMI enq sent 264842, LMI stat recvd 263185, LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0, LMI upd sent 0
LMI DLCI 0 LMI type is ANSI Annex D frame relay DTE segmentation inactive
FR SVC disabled, LAPF state down
Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 4w2d
Input queue: 0/75/1/0 (size/max/drops/flushes); Total output drops: 234335
Queueing strategy: weighted fair
Output queue: 0/1000/64/234287 (size/max total/threshold/drops)
Conversations 0/56/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1536 kilobits/sec
79921380 packets input, 3305006529 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
424053 input errors, 424053 CRC, 277121 frame, 47535 overrun, 0 ignored, 305798 abort
77380394 packets output, 260751799 bytes, 0 underruns
0 output errors, 0 collisions, 554 interface resets
0 unknown protocol drops
6 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
saludos
Hola,
Internet protocol processing disabled --> eso quiere decir que no tienes una dirección IP configurada en Serial0/0/1
¿Qué modelo de enrutador tienes? ¿Puedes publicar la configuración del enrutador?
