Error gettinf when i am going to save the conf.
a.rooprao
Hi aal,
I am getting the following error when i am going the save the configuration
Pune_Dist#write
Building configuration...
% Warning: Saving this config to nvram may corrupt any network management or sec
urity files stored at the end of nvram.
Continue? [no]: n
% Configuration buffer full, can't add command: line con 0
%Aborting Save. Compress the config.[OK]
Details are c3745-advsecurityk9-mz.124-5b.bin
gpulos
Level 8
Level 8
This is telling you your nvram is full.
Either compress the nvram contents, using the 'service compress-config' command or delete un-needed files that may be on the nvram.
Please see the following link for more info on compressing nvram:
http://www.cisco.com/en/US/docs/ios/12_3/configfun/command/reference/cfr_1g06.html#wp1053235
