Error on Serial interface of WIC Card ?????
afzaalq007
Some time i have seen Error on C-2600 on Serial interface's
That is
E1T1 NM Module Int S0/0:0 reciviing Excessisve errors.
what are the common reasons for this???
balajitvk
Level 4
Level 4
Could u mention the exact full error msg and software version so that it is easy to get into the probs???
Rgs
Thanks for the responose
the Full error is
%E1T1_Module-3-linefalp: Int S0/0:0 receiving Excessisve errord Pkacket
And the IOS verion of the router is 12.2(8)T5
%E1T1_MODULE-3-LINEFLAP: Interface [chars] receiving excessive errored packets
The serial interface is receiving an excessive number of error packets. This problem is caused by a controller configuration mismatch.
Check the settings for line code, framing, time slots, and speed.
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps1831/products_system_message_guide_chapter09186a00800f71a7.html#1025390
Rate if it does,
Rgs
