Error showing in Cisco 2821 Router
Hi Everybody,
I have a Cisco 2821 Router,when i accessing its console its showing below error. Please guide me to troubleshoot this problem.
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(3i), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 21:10 by stshen
Image text-base: 0x400A265C, data-base: 0x41C24FB0
Port Statistics for unclassified packets is not turned on.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Error: Unexpected NM Interrupt received from slot: 0
%Software-forced reload
burleyman
Level 8
Level 8
Did you make sure the module is supported with the IOS?
Has this ever worked or is this new?
Do you have the config off the router?
If you remove the module from slot 0, does the router boot with out error?
What is the model number on the module?
Mike
It was a working router & the modules are WIC-2T, NM-2CE1T1-PRI & WIC-1B-S/T-V3.I have already checked by removing the module from slot 0 & also removing all module from the router but it is showing same error during booting.
Could you please check the backplane of slot 0. Sometimes, this issue can also be seen due to bent pins or broken pins. If you find something abnormal, then the chassis has to be replaced.
Other thing that you can try is, try reseating the card in slot 0 again and also try upgrading the IOS to see if that helps. the IOS that you are running is already End of Life.
Hope this helps.
Vinit
--Vinit
Vinit Jain
Most of the cases, this indicates a hardware issue and needs replacement of the module that is showing the error. The only other thing you can try is either try physically reseating the module in slot 0 or try it in a spare router chassis (if available. Wouldnt recommend to try this on another production router).
If reseating doesn't resolve the problem, then you will have to replace the card in slot 0.
Vinit
--Vinit
