Error: TLB Modification exception, CPU signal 10, PC = 0x44128678
Hi guys,
One of our router, suddenly stopped working.
When we console in to the router and do a hard reboot, we receive this error message and doesn't boot up.
Here the logs:
System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Initializing memory for ECC
c2821 platform with 1048576 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x37142c8
Self decompressing the image : ###################################################################################################################################################################################################################################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
0003E8          0X00474800 C2821 Mainboard
                0X00264050 Onboard VPN
                0X000021B8 Onboard USB
                0X002C29F0 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X00BAE3F8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 12Mb.
Using 1 percent iomem. [12Mb/1024Mb]
   Possible hardware fault. This could be an one time occurence,
   upon reccurence please collect crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback= 0x441268D8z 0x4008CC14z 0x43227BA4z 0x4007FBB4z 0x40071118z
$0 : 00000000, AT : 46E10000, v0 : 00000000, v1 : 40000000
a0 : 3F400080, a1 : 00000000, a2 : FFFF3DEC, a3 : 00000000
t0 : 3FCFCF8B, t1 : 00000000, t2 : 00000001, t3 : BEEFBACC
t4 : BEEF0000, t5 : 00000000, t6 : FFFF9EF8, t7 : 80000000
s0 : 3F400080, s1 : 3F400050, s2 : 46E49240, s3 : 000037EC
s4 : 00000000, s5 : 00000020, s6 : 4322993C, s7 : 000037E8
t8 : 0088C868, t9 : 0000000F, k0 : 3040A801, k1 : A000F000
gp : 46E13980, sp : 8000ED58, s8 : 00000000, ra : 4008E9B4
EPC  : 44128678, ErrorEPC : BFC0038C, SREG     : 34008003
MDLO : 00000000, MDHI     : 00000000, BadVaddr : 40000000
CacheErr : D0800181, DErrAddr0 : 071E6370, DErrAddr1 : 06E49350
TEXT_START : 0x400116A0
DATA_START : 0x441A1DA0
Cause 00000004 (Code 0x1): TLB Modification exception
: TLB (load or instruction fetch) exception, CPU signal 10, PC = 0x0
   Possible software fault. Upon reccurence,  please collect
-Traceback= 0x400526DCz 0x40052B54z 0x40056344z 0x40055FC8z
$0 : 00000000, AT : 46E10000, v0 : 00000030, v1 : 46C60000
a0 : 471E5A24, a1 : A0001E89, a2 : FFFFFFFD, a3 : A0002215
t0 : 441AAED1, t1 : 441AAED0, t2 : 469A0000, t3 : 00000000
t4 : 469A0000, t5 : 00000000, t6 : 00000001, t7 : 00000001
s0 : 00000000, s1 : 00000000, s2 : A0001E89, s3 : 46490000
s4 : 00000038, s5 : 471E0000, s6 : 471E0000, s7 : 4712DFE8
t8 : 00000000, t9 : 46980000, k0 : 471E3BE8, k1 : 00000038
gp : 46E13980, sp : 46496BD8, s8 : 00000000, ra : 4005447C
EPC  : 00000000, ErrorEPC : BFC0038C, SREG     : 34008003
MDLO : 00000000, MDHI     : 00000004, BadVaddr : 00000000
CacheErr : D0800181, DErrAddr0 : 0712E010, DErrAddr1 : 0697FE80
Cause 00000008 (Code 0x2): TLB (load or instruction fetch) exception
Nested write_crashinfo call (2 times)
-Traceback= 0x40052714z 0x40052B54z 0x40056344z 0x40055FC8z
$0 : 00000000, AT : 46E10000, v0 : 00000027, v1 : 00000027
a0 : 00000002, a1 : 4712DFE8, a2 : 46C60000, a3 : 00000000
t0 : 441AB24D, t1 : 441AB24C, t2 : 34008000, t3 : FFFF00FF
t4 : 40058ED0, t5 : 00000000, t6 : 00000000, t7 : 00000021
s0 : 471E0000, s1 : 0000000A, s2 : 441B0000, s3 : 46490000
s4 : 00000038, s5 : 00000001, s6 : 00000000, s7 : 4712DFE8
t8 : 00000021, t9 : FFFFFFFF, k0 : 471E3BE8, k1 : 00000038
gp : 46E13980, sp : 46496B68, s8 : 00000000, ra : 400544B4
MDLO : 00000000, MDHI     : 00000002, BadVaddr : 00000000
CacheErr : D0800181, DErrAddr0 : 1FA80028, DErrAddr1 : 06496B60
Nested write_crashinfo call (3 times)
-Traceback= 0x40052B54z 0x40056344z
: 00000000, _P : 471E0000,  : 46490000,  : 471E0000
: 00011C81,  : 47470000,  : 46C60000,  : 400548F4
: 00000000, signal=10, sr=0x34008003, epc=0x41973B8C, err epc=0xBFC0038C
Could please someone assist us on this issue? And how to fix it?
Thanks and regards,
Jenalyn Forbes
ing_ivandez
Hello engineers!
Sorry for my late answer XD.
At the end it was an IOS problem, we contacted to Cisco TAC and they send us a testing IOS version, because also they had problems determining the exactly cause of the bug.
At this time, with this new IOS we have had no problems. Also, they told us that, with a regular upgrade to the next version, in some cases the problem is solved.
Thank you for the support!
Best regards.
6 Replies 6
ing_ivandez
Hi Jenalyn
I have the same problem that you have. My device is a CISCO1941/K9 and has crashed to many times with the next cause on the crash_info file:
13:04:40 UTC Thu Aug 1 2013: TLB Modification exception, CPU signal 10, PC = 0x230C3914
So, I wanna know if you found a workaround  or solution to this crashes and error. I appreciate that hyou can respon me.
Thanks. Ivan
You may need to consider upgrading your IOS, Ivan.
ing_ivandez
Hello engineers!
Best regards.
Can you please mark this thread as "Answered"?
I can´t because I didn´t open it XD
Ask Jenalyn
Regards!
ccie4297
One more solution for those who may also encounter this problem... I receieved the exact same error output and all I had to do was to reseat the RAM chips in our 2811 and voila, the problem is solved.
    Cheers,
        Ken
