Error when attempting to establish an vpn tunnel from cisco 892 router to palo alto device
jomo frank
Hello expert,
below is results of cypto debug
can you provide some guildance  how to fix this issue
AES-CBC SHA256 SHA256 DH_GROUP_2048_MODP/Group 14
*Mar 13 01:09:58.965: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Retrieve configured trustpoint(s)
*Mar 13 01:09:58.965: IKEv2:(SA ID = 1):[PKI -> IKEv2] Retrieved trustpoint(s): 'TP-self-signed-2325957854'
*Mar 13 01:09:58.965: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Get Public Key Hashes of trustpoints
*Mar 13 01:09:58.965: IKEv2:(SA ID = 1):[PKI -> IKEv2] Getting of Public Key Hashes of trustpoints FAILED
*Mar 13 01:09:58.965: IKEv2-ERROR:Failed to retrieve Certificate Issuer list
*Mar 13 01:09:58.965: IKEv2:(SESSION ID = 29,SA ID = 1):Sending Packet [To 181.199.253.181:500/From 190.80.24.247:500/VRF i0:f0]
Initiator SPI : CE3409DC1023875D - Responder SPI : 37C2A53BA4F7D585 Message id: 0
IKEv2 IKE_SA_INIT Exchange RESPONSE
Payload contents:
SA KE N VID VID VID VID NOTIFY(NAT_DETECTION_SOURCE_IP) NOTIFY(NAT_DETECTION_DESTINATION_IP)
*Mar 13 01:09:58.965: IKEv2:(SESSION ID = 29,SA ID = 1):Completed SA init exchange
*Mar 13 01:09:58.965: IKEv2:(SESSION ID = 29,SA ID = 1):Starting timer (30 sec) to wait for auth message
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):Received Packet [From 181.199.253.181:4500/To 190.80.24.247:500/VRF i0:f0]
Initiator SPI : CE3409DC1023875D - Responder SPI : 37C2A53BA4F7D585 Message id: 1
IKEv2 IKE_AUTH Exchange REQUEST
Payload contents:
IDi AUTH NOTIFY(ESP_TFC_NO_SUPPORT) SA TSi TSr
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):Stopping timer to wait for auth message
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):Checking NAT discovery
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):NAT OUTSIDE found
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):NAT detected float to init port 4500, resp port 4500
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):Searching policy based on peer's identity '192.168.90.2' of type 'IPv4 address'
*Mar 13 01:09:58.981: IKEv2-ERROR:% IKEv2 profile not found
*Mar 13 01:09:58.981: IKEv2-ERROR:(SESSION ID = 29,SA ID = 1):: Failed to locate an item in the database
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):Verification of peer's authentication data FAILED
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):Sending authentication failure notify
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):Building packet for encryption.
Payload contents:
NOTIFY(AUTHENTICATION_FAILED)
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):Sending Packet [To 181.199.253.181:4500/From 190.80.24.247:4500/VRF i0:f0]
IKEv2 IKE_AUTH Exchange RESPONSE
Payload contents:
ENCR
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):Auth exchange failed
*Mar 13 01:09:58.981: IKEv2-ERROR:(SESSION ID = 29,SA ID = 1):: Auth exchange failed
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):Abort exchange
*Mar 13 01:09:58.981: IKEv2:(SESSION ID = 29,SA ID = 1):Deleting SA
*Mar 13 01:10:03.257: IKEv2:Received Packet [From 181.199.253.181:500/To 190.80.24.247:500/VRF i0:f0]
Initiator SPI : 4593D10DF0031DDE - Responder SPI : 0000000000000000 Message id: 0
IKEv2 IKE_SA_INIT Exchange REQUEST
Payload contents:
SA KE N NOTIFY(NAT_DETECTION_SOURCE_IP) NOTIFY(NAT_DETECTION_DESTINATION_IP)
*Mar 13 01:10:03.257: IKEv2:(SESSION ID = 30,SA ID = 1):Verify SA init message
*Mar 13 01:10:03.257: IKEv2:(SESSION ID = 30,SA ID = 1):Insert SA
*Mar 13 01:10:03.257: IKEv2:Searching Policy with fvrf 0, local address 190.80.24.247
*Mar 13 01:10:03.257: IKEv2:Found Policy 'RBGL_BOG_POLICY'
*Mar 13 01:10:03.257: IKEv2:(SESSION ID = 30,SA ID = 1):Processing IKE_SA_INIT message
*Mar 13 01:10:03.257: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Retrieve configured trustpoint(s)
*Mar 13 01:10:03.257: IKEv2:(SA ID = 1):[PKI -> IKEv2] Retrieved trustpoint(s): 'TP-self-signed-2325957854'
*Mar 13 01:10:03.257: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Get Public Key Hashes of trustpoints
*Mar 13 01:10:03.257: IKEv2:(SESSION ID = 30,SA ID = 1):not a VPN-SIP session
*Mar 13 01:10:03.257: IKEv2:(SA ID = 1):[PKI -> IKEv2] Getting of Public Key Hashes of trustpoints FAILED
*Mar 13 01:10:03.257: IKEv2-ERROR:Failed to retrieve Certificate Issuer list
*Mar 13 01:10:03.257: IKEv2:(SESSION ID = 30,SA ID = 1):[IKEv2 -> Crypto Engine] Computing DH public key, DH Group 14
*Mar 13 01:10:03.257: IKEv2:(SA ID = 1):[Crypto Engine -> IKEv2] DH key Computation PASSED
*Mar 13 01:10:03.257: IKEv2:(SESSION ID = 30,SA ID = 1):Request queued for computation of DH key
*Mar 13 01:10:03.257: IKEv2:(SESSION ID = 30,SA ID = 1):[IKEv2 -> Crypto Engine] Computing DH secret key, DH Group 14
*Mar 13 01:10:03.257: IKEv2:(SESSION ID = 30,SA ID = 1):Request queued for computation of DH secret
*Mar 13 01:10:03.269: IKEv2:(SA ID = 1):[Crypto Engine -> IKEv2] DH key Computation PASSED
*Mar 13 01:10:03.269: IKEv2:(SA ID = 1):[IKEv2 -> Crypto Engine] Calculate SKEYSEED and create rekeyed IKEv2 SA
*Mar 13 01:10:03.269: IKEv2:(SA ID = 1):[Crypto Engine -> IKEv2] SKEYSEED calculation and creation of rekeyed IKEv2 SA PASSED
*Mar 13 01:10:03.269: IKEv2:IKEv2 responder - no config data to send in IKE_SA_INIT exch
*Mar 13 01:10:03.273: IKEv2:(SESSION ID = 30,SA ID = 1):Generating IKE_SA_INIT message
*Mar 13 01:10:03.273: IKEv2:(SESSION ID = 30,SA ID = 1):IKE Proposal: 1, SPI size: 0 (initial negotiation),
Num. transforms: 4
*Mar 13 01:10:03.273: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Retrieve configured trustpoint(s)
*Mar 13 01:10:03.273: IKEv2:(SA ID = 1):[PKI -> IKEv2] Retrieved trustpoint(s): 'TP-self-signed-2325957854'
*Mar 13 01:10:03.273: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Get Public Key Hashes of trustpoints
*Mar 13 01:10:03.273: IKEv2:(SA ID = 1):[PKI -> IKEv2] Getting of Public Key Hashes of trustpoints FAILED
*Mar 13 01:10:03.273: IKEv2-ERROR:Failed to retrieve Certificate Issuer list
*Mar 13 01:10:03.273: IKEv2:(SESSION ID = 30,SA ID = 1):Sending Packet [To 181.199.253.181:500/From 190.80.24.247:500/VRF i0:f0]
Initiator SPI : 4593D10DF0031DDE - Responder SPI : 8C5BBD1208B6B267 Message id: 0
Payload contents:
*Mar 13 01:10:03.273: IKEv2:(SESSION ID = 30,SA ID = 1):Completed SA init exchange
*Mar 13 01:10:03.273: IKEv2:(SESSION ID = 30,SA ID = 1):Starting timer (30 sec) to wait for auth message
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):Received Packet [From 181.199.253.181:4500/To 190.80.24.247:500/VRF i0:f0]
Initiator SPI : 4593D10DF0031DDE - Responder SPI : 8C5BBD1208B6B267 Message id: 1
Payload contents:
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):Stopping timer to wait for auth message
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):Checking NAT discovery
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):NAT OUTSIDE found
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):NAT detected float to init port 4500, resp port 4500
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):Searching policy based on peer's identity '192.168.90.2' of type 'IPv4 address'
*Mar 13 01:10:03.289: IKEv2-ERROR:% IKEv2 profile not found
*Mar 13 01:10:03.289: IKEv2-ERROR:(SESSION ID = 30,SA ID = 1):: Failed to locate an item in the database
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):Verification of peer's authentication data FAILED
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):Sending authentication failure notify
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):Building packet for encryption.
Payload contents:
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):Sending Packet [To 181.199.253.181:4500/From 190.80.72.149:4500/VRF i0:f0]
Payload contents:
ENCR
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):Auth exchange failed
*Mar 13 01:10:03.289: IKEv2-ERROR:(SESSION ID = 30,SA ID = 1):: Auth exchange failed
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):Abort exchange
*Mar 13 01:10:03.289: IKEv2:(SESSION ID = 30,SA ID = 1):Deleting SA
Bog#
Bog#sh run
Building configuration...
Current configuration : 4913 bytes
Francesco Molino
There’s an authentication failure.
Can you share the config on both sides or can you validate the authentication on the Cisco and Palo Alto?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
miraziz
Hello truth seekers fellows!
i have the similar logs...
#sh crypt ikev2 diagnose
Error(8789): Failed to retrieve issuer public key hash list
same TP-self_signed certificate...
any one ?
