Error when copy flash to cisco Router.
jomo frank
I getting the following error when attempting to copy image to flash, it should be mentioned I use two different Tftp Server applications but the result the same
Bog#copy tftp flash:
Address or name of remote host [192.168.42.210]?
Source filename [c890-universalk9-mz.158-3.M6.bin]?
Destination filename [c890-universalk9-mz.158-3.M6.bin]?
Accessing tftp://192.168.42.210/c890-universalk9-mz.158-3.M6.bin...
%Warning: File not a valid executable for this system
Abort Copy? [confirm]
I have included additional information about the router for your guidance
Bog#sh ver
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.3(3)M5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 04-Feb-15 11:24 by prod_rel_team
ROM: System Bootstrap, Version 15.2(3r)XC, RELEASE SOFTWARE (fc1)
Bog uptime is 1 week, 6 days, 3 hours, 56 minutes
System image file is "flash:/c800-universalk9-mz.SPA.153-3.M5.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C892FSP-K9 (revision 1.0) with 488524K/35763K bytes of memory.
Processor board ID FTX19138015
10 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 32 bits wide
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        C892FSP-K9            FTX19138015
License Information for 'c800'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
 - As a sanity check ,try another release, preferably one of the suggested releases, check if the problem persists or not.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 - Make sure the correct image is being downloaded (double check on the router model)
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Hello Marce,
I confirm the router mode is C892FSP-K9.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Hello Marce,
I found the error the model router  C892FSP-K9    has it own ios c800-universalk9-mz.SPA.158-3.M6.bin.
