Home Lab
Noob22
Im trying to follow the below lab But now I need to add a catalyst 3750. WHat configuration do I need on the router for the switch to provide IPs?
Router 1
Router#Config t
Router(config)#hostname R1
R1(config)#enable password $$$$
R1(config-line)#line vty 0 4
R1(config-line)# password $$$$
R1(config-line)# login
R1(config-line)#exit
R1(config)#interface Serial0/0
R1(config-if)#ip address 10.1.1.1 255.0.0.0
R1(config-if)#clockrate 64000
R1(config-if)#no shut
R1(config)# exit
R1(config)#interface Serial0/1
R1(config-if)#ip address 11.1.1.1 255.0.0.0
R1(config)#exit
R1(config)#router ospf 100
R1(config-router)# network 10.0.0.0 0.255.255.255 area 0
R1(config)#exit
R1(config)#router bgp 100
R1(config-router)# no synchronization
R1(config-router)# network 11.0.0.0
R1(config-router)# neighbor 10.1.1.2 remote-as 100
R1(config-router)# neighbor 10.1.1.2 route-reflector-client
R1(config-router)# neighbor 11.1.1.3 remote-as 100
R1(config-router)# neighbor 11.1.1.3 route-reflector-client
R1(config-line)#end
R1#wr
--> Im trying to follow the below lab But now I need to add a catalyst 3750
What lab are you referring to ? What is the context of your question, what is your topology supposed to look like ?
here is a sample config for a router on a stick setup:
1941
ip dhcp excluded-address 192.168.10.1
ip dhcp excluded-address 192.168.20.1
ip dhcp excluded-address 192.168.30.1
ip dhcp pool VLAN10
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8 4.2.2.2
ip dhcp pool VLAN20
network 192.168.20.0 255.255.255.0
default-router 192.168.20.1
ip dhcp pool VLAN30
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
interface GigabitEthernet0
description Downlink to 3750 switch
interface GigabitEthernet0.10
encapsulation dot1q 10
ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet0.20
encapsulation dot1q 20
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0.30
encapsulation dot1q 30
ip address 192.168.30.1 255.255.255.0
3750
interface GigabitEtherne0/0
description Uplink to 1941 router
switchport mode trunk
interface GigabitEthernet0/1
switchport mode access
switchport access vlan 10
spanning-tree portfast
interface GigabitEthernet0/2
switchport access vlan 20
interface GigabitEthernet0/3
switchport access vlan 30
interface Vlan 1
ip address 192.168.1.2 255.255.255.0
ip default-gateway 192.168.1.1
