Error when i config pppoe-client dial-pool-number 1
atifsalahnour
Router(config)#int f0/0
Router(config-if)#des DSL
Router(config-if)#no ip add
Router(config-if)#pppoe enable
Router(config-if)#pppoe-client dial-pool-number 1
% Invalid input detected at '^' marker.
Mark Malone
Havre you created the dialer and group fist there and then try apply it  to f0/0 ?
interface Dialer1
ip address negotiated
ip nat outside
ip mtu 1492
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
ppp authentication pap
ppp pap sent-username xxxx password xxxx
rizwanr74
Level 7
Level 7
Try these command instead.
 pppoe enable group global
Peter Paluch
Friends,
Please allow me to join.
Mark: I am afraid that defining a Dialer interface has no impact on whether the pppoe-client command is accepted or not.
Rizwan: Your suggestion would start a PPPoE server instead of PPPoE client on the interface. I don't believe that this is what atifsalahnour intends to do.
Atifsalahnour: Do not enter the pppoe enable command by yourself. Try to clear the interface configuration using the default interface fa0/0 command, and after that, try entering the pppoe-client dial-pool-number 1 on the Fa0/0 inerface directly without any preceding commands. If the command is still not accepted please let us know your exact IOS version and feature set. There is a possibility that the PPPoE client feature is not supported.
Best regards,
Peter
