Error while booting CISCO 2800 Series Router
Tahir Munir
Hi All,
While booting router, facing mentioned below issue. Please help me to resolve this issue. Upgrade ROMMON initialized PASSWORD RECOVERY FUNCTIONALITY IS DISABLED program load complete, entry point: 0x8000f000, size: 0xcb80 boot: cannot determine first executable file name on device "flash:" c2821 platform with 262144 Kbytes of main memory Main memory is configured to 64 bit mode with ECC enabled
Tahir Munir
M02@rt37
Hello @Tahir Munir,
The error message you're encountering during the boot process of your Cisco router indicates that the router is unable to determine the first executable file name on the "flash:" device. In otjer words, the router is unable to locate the appropriate IOS image to load from the flash memory.
You might need to enter the router into ROMmon mode and attempt to recover the system.
Because password recovery is disabled, then you have a very short interval after the image is loaded to hit break and get a prompt that asks if you want to recover the router.
Note that 2821 should have a flash card. If you eject the flash card and reboot, the router will boot into ROMmon.
Tell us when you are in ROMmon.
Best regards
balaji.bandi
check below guide how you can recover :
https://community.cisco.com/t5/networking-knowledge-base/cannot-break-to-rommon-because-the-no-service-password-recovery/ta-p/3131504
BB
Leo Laohoo
Someone removed the CF?
