Esa Cluster
Hello everyone,
I'm configuring new Esa cluster because, the ip address of it are changed so that,
I would like to know if the cluster needs to communicate to ldap or others networks services .
Another question is regards to the gateway, In which way is possible to add it to a management network ?
I try to do it by using command "setgateway" now, in both the devices there is a static route that allow to send traffic by using a production environment , as you can image before add/modify it I need to be sure that everything continue to work as excpected.
Many thanks for your attention
Awaiting your news.
Rgds,
0 Replies 0
