ESP20 can only handle 10G of total throughput?
firmanperdi
We have a Cisco new ASR1004 + RP2 + ESP20 + ISP40 in expectation to handle our 16Gbps total traffic, but we only get 10G traffic from the box, flat, with constant spike on latency and packet loss.
We've tried a few different configuration, but the result still the same, the ASR1004 can only handle 10G of total traffic.
1. ASR1004 + RP2 + ES20 + ISP40 (2x 20Gbps portchannel) = only 10G total traffic
2. ASR1004 + RP2 + ES20 + 2x ISP40 (20Gbps portchannel each ISP) = only 10G total traffic
Can anyone confirm that the ESP20 is actually only capable to handle 10G of total traffic? our traffic is limited by its 11.5Gbps ESI?
Here some additional information from our router:
Cisco IOS XE Software, Version 03.16.02b.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.5(3)S2b, RELEASE SOFTWARE (fc1)
System image file is "bootflash:/asr1000rp2-adventerprisek9.03.16.02b.S.155-3.S2b-ext"
asr-bdg#sh platform
Chassis type: ASR1004
Slot Type State Insert time (ago)
0 ASR1000-SIP40 ok 2d18h
0/0 SPA-1X10GE-L-V2 ok 2d16h
0/1 SPA-1X10GE-L-V2 ok 2d17h
1 ASR1000-SIP40 ok 2d18h
1/0 SPA-1X10GE-L-V2 ok 2d17h
1/1 SPA-1X10GE-L-V2 ok 2d17h
1/2 SPA-2X1GE-V2 ok 2d18h
1/3 SPA-2X1GE-V2 ok 2d18h
R0 ASR1000-RP2 ok, active 2d18h
F0 ASR1000-ESP20 ok, active 2d18h
P0 ASR1004-PWR-AC ok 2d18h
P1 ASR1004-PWR-AC ok 2d18h
asr-bdg#sh etherchannel sum
Group Port-channel Protocol Ports
1 Po1(RU) LACP Te0/0/0(bndl) Te1/0/0(bndl)
2 Po2(RU) LACP Te1/1/0(bndl) Te0/1/0(bndl)
asr-bdg#sh hw-module all fpd
H/W Field Programmable Current Min. Required
Slot Card Type Ver. Device: "ID-Name" Version Version
0/0 SPA-1X10GE-L-V2 1.2 1-10GE I/O FPGA 1.11 1.9
0/1 SPA-1X10GE-L-V2 1.2 1-10GE I/O FPGA 1.11 1.9
1/0 SPA-1X10GE-L-V2 1.5 1-10GE I/O FPGA 1.9 1.9
1/1 SPA-1X10GE-L-V2 1.2 1-10GE I/O FPGA 1.11 1.9
1/2 SPA-2X1GE-V2 1.0 1-2xGE V2 I/O FPGA 1.1 1.1
1/3 SPA-2X1GE-V2 1.0 1-2xGE V2 I/O FPGA 1.1 1.1
asr-bdg#sh platform resources
**State Acronym: H - Healthy, W - Warning, C - Critical
Resource Usage Max Warning Critical State
RP0 (ok, active) H
Control Processor 5.00% 100% 90% 95% H
DRAM 5165MB(65%) 7907MB 90% 95% H
ESP0(ok, active) H
Control Processor 17.19% 100% 90% 95% H
DRAM 1122MB(29%) 3785MB 90% 95% H
QFP H
TCAM 8cells(0%) 524288cells 45% 55% H
DRAM 190217KB(18%) 1048576KB 80% 90% H
IRAM 10453KB(7%) 131072KB 80% 90% H
SIP0 H
Control Processor 2.20% 100% 90% 95% H
DRAM 312MB(32%) 946MB 90% 95% H
SIP1 H
Control Processor 3.70% 100% 90% 95% H
DRAM 372MB(39%) 946MB 90% 95% H
Thank you,
0 Replies 0
