ether channel
bsudol79p
Hi, can someone tell me the when I would use leyer 2 instead of layer 3 ether channel configuration. I want to implement ether channel to the servers and I don't know which one would be appropriate. Thanks for your help.
Istvan_Rabai
Level 7
Level 7
Hi Bart,
If you didn't implement Etherchannel but used a single port configuration, what would you use? A layer2 or a layer3 port?
If you used a layer2 single port, then you could implement a layer2 Etherchannel.
If you used a layer3 single port, then you could implement a layer3 Etherchannel.
Cheers:
Istvan
Istvan_Rabai
Level 7
Level 7
Hi Bart,
Cheers:
Istvan
Thanks that answered my question very clearly.
