etherchannel with layer 3
ivpere0032
Hi im trying to connect two swiches layer 3 with etherchannel and also route the vlans. I did the first part but i dont knows how to add the vlans for routing un the port chanbel. Thanks for the help !
Vinit Jain
You can create layer 2 port-channel and make it a trunk port. Then you can create SVI's for the vlans that you want to be part of Layer 3. Add those vlans to be allowed on the trunk or you can leave the trunk port as is to allow all the vlans.
This way you can have both layer 2 and layer 3 traffic pass through the etherchannel. Sample config of port-channel below.
SW5(config)#int rang e0/1-2
SW5(config-if-range)#chann
SW5(config-if-range)#channel-gr
SW5(config-if-range)#channel-group 1 mode on
Creating a port-channel interface Port-channel 1
SW5(config-if-range)#int port-channel 1
SW5(config-if)#switchport
SW5(config-if)#switchport trunk encap dot
SW5(config-if)#sw mode trunk
SW5(config-if)#exi
SW5(config)#vlan 100
SW5(config-vlan)#exi
SW5(config)#interface vlan 100
SW5(config-if)#ip add 100.1.1.1 255.255.255.0
SW5(config-if)#no shut
SW5(config-if)#
Hope this Helps.
Please let me know if you have any further questions.
Vinit
--Vinit
