Why do we need to use ASR/ISR router instead of common router ?
eigrpy
Level 4
Level 4
Why do we need to use ASR router instead of common router in edge of network ? Any expert can explain it ? Thank you
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes, that's true relative to the ISR series.  Not always true vs. other vendor routers.
Also, of course, bandwidth varies within the same series too.
The only way to answer this is what features do you need? then select the appropriate router.
I checked some document. One of them states that ASR have bigger bandwidth than other router
https://supportforums.cisco.com/sites/default/files/legacy/0/0/8/82800-ISR%20vs%20ASR.pdf
Disclaimer
Posting
Joseph W. Doherty
Disclaimer
Posting
You mean, why Cisco rather than brand X?  (Especially as the former is often more expensive than the latter.)
Well there might not be any true need.  However, from experience with both Cisco and different brand X equipment, Cisco equipment often has features not found on other vendor equipment and if often works correctly (and when it doesn't they often actually fix it so it does).
You might not now or ever need Cisco's additional features, and other vendor equipment sometimes works as it's supposed to, too.
You might be very happy with a "common" brand X router, or likewise unhappy with a Cisco router.  But, my experience has be the odds often favor the converse.
If price is an issue (and when isn't it?), what can help is to correctly "right size" the Cisco equipment.  For example, do you really need an ASR, or will an ISR do the job?  (BTW, keep in mind, anyone selling hardware, including Cisco, does have a tendency to up size their recommendation.)
