ETHERCHANNELING AND REDUNDANCY
okoroji80
Dear support Team,
How can I Setup Two Router for redundancy for the following solution
  • •1.       Setup up two routers with three(3) connections: A,B,& C ( RJ 45 Cat6 cable) to each other
  • •2.       The three connections are complimentary to each other
  • •3.       The connection is such that if a user at RouterA is accessing a server resource at RouterB, all the links are active at the same time  such that if link A fails, it automatically switches over to start using link B, in the event of link B failing, it will switch to using link C
  • •4.       In between the routers interfaces: A,B & C there will exist etherchannel/ bondling
Thomas Schmitt
DUplicate post - https://supportforums.cisco.com/message/4148004#4148004
Kind Regards
Paul
