Ethernet over copper
angel-moon
Level 3
Level 3
Hello everyone,
can anyone tell me is Cisco has any products that can terminate Ethernet over Copper connections?  If not then can you point me to a good product that can?
Thanks in advance!
To the best of my knowlege, no. There is also ANDA . Used 'em for OC-x to ethernet services. the carrier provided.
6 Replies 6
Richard Burts
Perhaps there is something in your question that I do not understand correctly, but it seems to me that the answer to your question is that almost every Cisco Catalyst switch has cards that will do Ethernet over copper.
Rick
Rick
I guess I should have been more specific.  I meant something like what Hatters Networks or Oveture Network has where you have a WAN device that can terminate several twisted coper pairs onto a device and convert it into Ethernet
Is this a carrier based service you are bringing in? If so, the carrier should provide the terminating hardware, and present you with an ethernet interface.
No.  This is for a small CLEC who is a customer of ours.  They want to start offereing this service and are looking at Hatters network for the terminating devices so that THEY can give the Ethernet handoff.  I just wanted to see if Cisco had a device that can do what teh Hatteras does.
Thanks for the reply.  I didn't think so but wanted to check.  Thanks for the ANDA reference as well.
